Author Topic: 'Boutique gear' general grumpy rant.  (Read 114809 times)
Re: 'Boutique gear' general grumpy rant.
« Reply #195 on: July 26, 2013, 11:17:30 AM »
I think you're right Elliot, but what the blind test really told me was that the 3 Monkeys and the Morgan weren't that great.  I wonder why they chose them instead of a Lazy J/Friedman/Divided by 13 etc?  Why choose complete unknowns, small companies who could be cobbling anything together?
That is a good point - being a bit dopey about amps I hadn't heard of those brands, but I assumed it was just me!
The thing that struck me most about the article wasn't about which amps were "better", it was the really bad job the "experts" made of guessing which amp was which.  Pulling names out of a hat would've been just as successful.
« Reply #196 on: July 26, 2013, 11:25:44 AM »
I believe Brad Whitford of Aerosmith uses a 3 Monkeys, amongst many other things, otherwise they're unknown.  I don't know of anyone using a Morgan, and I only know of them through World Guitars' website.
Which is why I took the blind test with a pinch of salt, it told me nothing other than Mick Taylor is awesome!  :lol:
jpfamps
    • http://www.jpfamps.com
« Reply #197 on: July 26, 2013, 11:43:45 AM »
If people always ask for mods then it's going to be easier to make stuff a bit more bespoke, although to be fair if you were running a small company it's probably worth building a few amps at the same time, since that will give you stock exponentially faster than doing one amp after another in a consecutive process. Building 3 amps at once by hand is faster than building 3 one after the other (is what I'm getting at) and therefore uses time more efficiently.
I've seen at least one "boutique" amp company advertise the fact that they make their amps "one at a time".
jpfamps
« Reply #198 on: July 26, 2013, 11:47:43 AM »
3 Monkeys are pretty well know.
I've only recently become aware of Morgan amps.
Print journalism runs to very tight deadlines, and whilst it would be nice to have a "better" selection of amps for this type of shoot out you are often limited by what's available.
« Reply #199 on: July 26, 2013, 11:56:34 AM »
I know of a couple of people playing Morgans, but not many. They like them.
« Reply #200 on: July 26, 2013, 03:38:25 PM »
(a) The point about the Guitarist test is not that the clean tones of the Hot Rod were 'very good (especially for the price)' or 'a good cheap option' (both statements I can imagine being said with upturned noses - if I didn't know you both from here for years  :D) but were preferred to the clean tones of amps costing 5 times the price in a blind test.  The Hot Rod sounded boutique, the boutique amps didn't - and that to the ears of professional musicians.  Now, I must confess I have never played a Hot Rod Deluxe, although I know the Blackface tone it based on - but if people who play and review guitars and amps for a living think by their ears alone  that amp is the booteek amp, then, unless posh amp builders don't bother with their clean sound (which is hard to imagine), they aren't doing it right and thus the £$$$$££$£ is questionable.
(b) It is interesting to note that the same magazine compared a Joyo UD with Fulltone OCD and came out the other end - stating that anyone with pro-musician ears could tell the difference.
(a) Yeah I appreciate that.
I guess all I meant was that, for me, I can understand why the hot rod is on the cheap(ish) side of things, because I need a good distortion channel too- to me, there are better options than the HRD for what I want (and admittedly I'm more biased towards dirty tones). Not necessarily for more money than the HRD, of course, to me the traynor ycv is better and cheaper (on thomann, when they have them in stock).
But you do make a good point (which we possibly ignored), which is that, if you ignore the other channels on the HRD, and compare it to (often quite expensive) amps which only have a clean channel, it may well hold its own against them (or come out ahead).
But i'd be the first to admit that a lot of guitarists are full of it, and listen with their eyes (or wallets). Or maybe it's just people in general. :lol:
(b) yeah i read that article (it's the only guitarist mag I've bought in years). I actually didn't agree with some of the claims (not that I'm qualified to disagree, lol). I wondered at the logic of allowing someone who actually makes some boutique stuff (or who, at very least, is a self-confessed boutique fan) to be a supposedly independent or indifferent reviewer...
they also didn't mention about the bugera's mdf/particleboard (i assume) cabinet when comparing the bugera to the matchless. which was a pretty big oversight, i thought.
also regarding the point about the slightly weird choice regarding which boutique amps were picked (and not completely forgetting jpf's point about the tight schedules, which probably also played a large part in the choice), the cynic in me wonders if larger/more well-known boutiquers were approached and refused to take part :lol: if you're already well-known and selling well, you don't have much to gain by taking part in a test which may well conclude that your expensive amps actually aren't worth it :lol:
Funny enough, I've been wanting a Joyo US Dream because I've always wanted a Suhr Riot.. Should I?
Any other Joyos worth buying too?
most of them are pretty good, assuming they're not DOA (seems to be the main cause of faults) and assuming you don't need bombproof reliability. Some are better than others, of course, and there also might be better options on the cheap for specific pedals (for example, i'd get the digitech bad monkey over the joyo vintage overdrive- neither really sounds better, but the digitech has that bass control which is pretty handy).
« Last Edit: July 26, 2013, 03:40:49 PM by dave_mc »
JJretroTONEGOD
  • JJ Retro w/Mule + BKP90
« Reply #201 on: July 26, 2013, 04:30:14 PM »
suhr custom shop v.s £50 chinese 90s squier... which one would win in a double blind test?
the cheapest epiphone LP v.s a 1959 Gibson Les Paul...which one would win?
a £10 charity shop violin v.s a stradivarius from 1721?
tekbow
« Reply #202 on: July 26, 2013, 05:44:44 PM »
Yup, You're right, there are definitely limits to which the boutique vs budget arguments will not stretch
« Reply #203 on: July 26, 2013, 06:41:33 PM »
Something I forgot. The amps came from different places. Personal collections and also from stores in the UK. I know a Splawn was sent to that test from Toneworld in Manchester for example. The reason they didn't try a Friedman or whatever may simply be they were harder to get hold of. I doubt any companies backed out of being involved, I'd even doubt if any were really asked to take part! I'll try and find out a bit more about it.
The point about the cab construction is a good one. This is the stuff that should be mentioned in a reviews besides tone. The old Laney AOR headshells are particle board with glued joints. Not finger/dovetail joints. Just one board glued against another wraped in tolex with plastic corner protectors. Maybe that doesn't matter all that much, but a nice cab with proper joints and stronger materials is probably less likely to crack if dropped or something. I sat on my old laney headshell once and heard is make a loud cracking noise!
Along the same lines, a reviewer could also point out that a large transformer on a 1.6mm thick aluminium chassis is at risk of tearing holes in the metal where it's mounted. Other situations can occur when parts will sheer off metal in amps too.
You never hear reviewers point out stuff like that. They just open stuff up like the matchless Independence and say "isn't it beautiful! 10 out of 10!" when really that should say "Isn't it beautiful! Pray to god nobody ever has to work in there!"
JJretroTONEGOD
« Reply #204 on: July 26, 2013, 07:46:17 PM »
:D
« Reply #205 on: July 27, 2013, 04:39:33 PM »
^ ^ yeah exactly. if you're not expert enough to write about that stuff, why am i buying your magazine again? :lol:
Lucas
« Reply #206 on: August 01, 2013, 11:17:32 PM »
I would consider myself as gear snob as well, but I would never go as far as going for a 5k guitar for sure.
You can reach definitely better effect by getting a decent mid-priced guitar around 1k or a little bit more and upgrade it yourself.
I went that road.
I bought Dean Cadillac Select (Korean) for about 500 and replaced/upgrade pretty much everything with the stuff I knew and knew its quality.
Upgrades:
-Sperzel locking tuners
-professionally cut bone nut
-Buzz Feiten tuning system
-stainless steel frets
-abalone markers
-BKP Naibomb
-BKP Cold Sweet
-Graph Tech brigde and tail piece
-Shaller strap locks
-and soon CTS pots and Jersen caps
Some work I`ve done myself, some professional luthier
After that that guitar became truly luthier top class instrument which plays waaaay better than some 2-3k or maybe more??? guitars.
All those things cost me another 1k, so spending around 1,5k you have a true gem with the stuff you find useful for yourself.
On the other side when you play live, during the gigs 99% of people who listen to you first of all dont give a $%^# what gear you play whereas its 10k some uber custom PRS or Chinese Strat copy for 300 as long as they enjoy themselves and can listen to some good music. First of all they dont care and what`s more most of them wouldn`t notice any difference as well as wouldn`t know any difference either.
And two funny situations come to my mind. Some time ago in my town there was a blues festival with loads of live music in some pubs.
At one of them there was some guitar player with loads of good gear kind of 'boutique-ish', once I was talking to people outside about the way he plays and gear he uses most of them agreed that he plays well, but didn`t care about the gear at all.
And the second situation was at the same festival. In one of those bands there was an truly amazing guitar player with absolutely OUTSTANDING sound, seriously that guy sounded brilliant. Once I came closer I started looking at his gear, `cause his sound stroke me being really immense.
And guess what?? Standard Gibson LP, Roland jc-120 stereo chorus and few ordinary BOSS pedals like overdrive, tuner ect. And without any custom boutique gear worth 13k that guy blew everything away within 10 miles with his sound!!!!! Was surprised must admit.
So what is the conclusion?
« Last Edit: August 01, 2013, 11:21:13 PM by Lucas »
« Reply #207 on: August 02, 2013, 12:17:41 AM »
Recently bought a used, but still like new, Boss BD-2. Great pedal for no money. Like the Bad Monkey, there are some cheap gems on the market.
Lucas
« Reply #208 on: August 02, 2013, 01:15:42 AM »
well, when it comes to Boss, I still find Boss CH1 as a really great chorus pedal, nearly iconic one even when without 'boutique' label on it.
