Blackguard tele pickups: flat 50s va staggered 55
Started by josetxu, July 27, 2013, 03:38:49 PM
josetxu
Hi everyone!
I have an ash/rosewood telecaster (with steel saddles) and I'm looking for a new set of pickups. I've tried a telecaster with the same woods but thinner neck (mine has a 1" neck) and brass saddles with the flat 50s and they sounded great. I want a set but I've also seen that the staggered 55 are more suitable for rosewood. How does the two sets differ? I have another telecaster with Lollar vintage T so I want a bigger, fatter sound out of this guitar. What do you recommend?
I would try a Flat 52, I have both types of flatpole and I've played the stagger pole.  I think the stagger poles are not as thick sounding as the flatpoles.  If you're after a fat sound then either of the flatpoles will suit.  I prefer the 52 neck pickup, but then I'm not a big fan of tele neck pickups.
Quote from: PhilKing on July 27, 2013, 04:30:52 PM
I concur with this! The Flat 52 (actually the old BG50, which is now the flat 52) does a great job in my Fender American Series (alder/rosewood). The neckpickup is quite stratty, which I like.
BigB
Another vote for the Flat52 here. Mines are in MiJ Custom '62 RI / rosewood neck and they sound just right, I don't think it could be any better.
josetxu
But looking at the specs they seem very similar to the Lollars I have in my other telecaster: Alnico V, 42 Gauge wire... only the Lollars seems to have even more winding (BKP 5K vs Lollar 5,6K in neck pickup and BKP 7,1K vs Lollar 7,4k).
Another question: stock vs RW/RP? in my strats all the sets I have are stock as the in between positions sounds better that way in my opinion, but it's the same in telecaster pickups?
Quote from: josetxu on July 28, 2013, 11:29:52 AM
Question is if you want humcancelling middle or not. Personally I too prefer non humcancelling (stock winding) as humcancelling always kills other frequencies too. Plus I don“t mind that bit of hum.
BigB
Similar specs doesn't necessarily mean similar tone, but well, I've not played the Lollars so I can't say. Now you can just AskTim(tm), and at worse there's this 14 days return policy thing  8)
Stock definitly as far as I'm concerned. Not that I like hum, but what's the point of having (partially at best) "hum-cancelling"  in only *one* position ?
josetxu
Finally went with the flat 50s, stock polarity. I've just installed them and I think they're just what I was looking for. Bridge pickup is similar to the lollar in the other guitar but fatter, just what I wanted and the other two positions are very different to my other telecaster. Middle position it's fuller, less quacky (better in my opinion, I prefer that way) and neck is fuller, darker and less stratty (I have 3 strats).
So really happy with them, thinking in trying a set of strat pickups now  :D :D :D
