Author Topic: Bare knuckle the sinner problem  (Read 2003 times)
elcuervo
« on: July 31, 2013, 10:11:11 PM »
Hi!, I have a marhall jcm200dsl 100 head ,I put the lead 2 channel in the maximum gain ,but the high E string is weak and poor in gain ,in the neck PU mainly.The PU is a bare knuckle the sinne(single coil) ,is a hot PU ,but this problem turned me crazy!!!! Maybe is normal in this amp ,I dont know ,Regards!!!!!
Pd: the pickups height is OK!
darrenw5094
Re: Bare knuckle the sinner problem
« Reply #1 on: August 01, 2013, 01:27:34 AM »
Something wrong obviously, possibly the amp, as in the pre amp valve (tubes).
If not, then the pickup might have been soldered in ass ways or bad quality solder point.
Get a tech to check the insides of the guitar.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
elcuervo
« Reply #2 on: August 01, 2013, 01:53:25 AM »
Maybe a preamp tube ,But the soldering is ok ,i believe that the sinner neck  Isn't good for high gain like a bridge version.
But the really strange is that I connect my radial bones london distorion with very low gain to the amp ,(the amp only cruchy) the sound is amazing! ,low pedal gain+low amp gain=Good tone ,But Amp with maximum gain setting Isn't good on.Its crazy!!!! :shock:
elcuervo
« Reply #3 on: August 01, 2013, 08:57:49 PM »
Up!!!!
blue
« Reply #4 on: August 02, 2013, 12:55:24 PM »
i think you might have answered your own question.  the DSL will become mushy and and indistinct with the gain up full, but setting it for a crunchy tone and then using a drive or boost pedal will result in a more articulate and tighter sound.
