Author Topic: Ready to buy 1st expensive guitar. Advice needed?  (Read 18137 times)
Cam_H
  • BKPs: VHII (B) - '63 Veneer Boards (N,M)
« on: August 24, 2013, 03:25:57 PM »
Hi all.
Shortly I'm going to start looking round for a couple guitars which will be my first expensive guitar I've owned. In the past, most of my guitars have been up to the £500 mark.
What I wanted to ask was, what can I expect from a more expensive guitar? I have all my guitars set up anyways so the stock set-up in terms of playability isn't really an issue here.
One guitar I've been looking at is the ESP Eclipse Full Thickness. Is this guitar really worth double the price of an LTD EC-1000?
Another things which I'm curious about is - when I'm in a guitar shop playing the more expensive guitar, what are the top things I should be looking for when I pick up the guitar? It may sound noobish, but I honestly don't know when I pick up an expensive guitar, what I should be looking for straight away? If I was to pick up an Epiphone Les Paul Custom and a Gibson Les Paul Custom, what would you say I'd notice in terms of difference? And would these differences be worth the extra £1.5k?
Bit random, but I'm just trying to broaden my scope into what a good guitar should consist of.
Re: Ready to buy 1st expensive guitar. Advice needed?
« Reply #1 on: August 24, 2013, 04:10:01 PM »
In general you could say better woods (in case of LP real maple top, no veneer), better materials like pots, nut and tuners, better playability/fretdress, better craftmanship. But, you have to feel and play a more expensive guitar and compare it to the a more affordable one. Then you can decide if the 'expensive' guitar is worth the extra money.
« Last Edit: August 24, 2013, 05:53:12 PM by Telerocker »
« Reply #2 on: August 24, 2013, 04:32:19 PM »
A lot of Epiphones I've seen recently have had awful white marks on the fretboards - the rosewood they use sometimes looks like it was taken from a briny swamp - and the frets are poorly finished.  Same with the cheap end of the LTDs (the 50s & 100s, not the 1000s you mention).
The camo finish ESP Vipers have a very nice satin feel on the back of the neck, that I did notice.
Tokai make a vintage series SG that is selling for the same price as the Gibson SG Standard and quite a few people say its better, so made in Japan and made in USA are about the same.  I'm not too pleased with the price of the ESPs  though, I think they are overpriced.  If the ESP Viper was the same price that I got my Gibson SG Standard for I would have seriously considered it.  I don't like EMGs much but I ended up swapping out the brand new 490/498 set and wiring harness in my Gibson anyway
Cam_H
« Reply #3 on: August 24, 2013, 05:22:55 PM »
Say, if an Epiphone Les Paul Custom cost £500, plus a full set up (£70 which includes fret dressing,) and hardware upgrade (pots, pickups, bridge, etc) totalling £1000. Would a Gibson Les Paul Custom still be worth that £1k+?
Nadz1lla
    • Arcanum Plectra
« Reply #4 on: August 24, 2013, 05:26:14 PM »
This +1
It depends on what you're looking for in a guitar. If you're buying an expensive guitar just for the sake of buying an expensive guitar, then you don't need / won't feel the benefit of spending all that money.
Like Tele says, generally things like the kind of wood the guitar is made out of, the quality of the hardware etc will have the majority of influence on the price. A Swamp Ash guitar will, generally, be much more expensive than something like a Bronze Series B.C Rich because Bronze series are made from plywood. Also, a one-piece Ash guitar will generally be more expensive than a two or three piece version.
If you want to spend a lot of money on a Guitar, then I would highly recommend going custom, as that way you can have everything perfectly to the exact spec you want and you won't have to compromise on any of it at all. The only limit is how much you want to spend.
My opinion: don't buy anything unless you actually need it. If you feel that you'll get more of the tone you're after with a guitar made of a certain tone-wood and none of your existing axes are going to cut it, then yes, buy a new guitar, but certainly don't "aim" to spend a lot of money unless it's going to be something you can seriously justify.
Anyone who spends a lot of money on a guitar just so they can say they own a PRS or whatever, they are doing everything for entirely the wrong reason.
Cam_H
« Reply #5 on: August 24, 2013, 05:46:45 PM »
I just read on a lot of forums that the wood quality on certain guitars in the £1k+ range out do cheaper guitars. I am happy with my cheaper guitars, but I'm interested in taking it to the next level. I may buy an expensive guitar and over time realise how much better it is. But I just wanted to be prepared for it.
You bring an interesting point with the 2/3 piece guitars. How would you say they compare to a guitar body built from only 1 piece?
« Reply #6 on: August 24, 2013, 05:58:03 PM »
That depends on the quality of the wood. A onepiece body is not a guarantee to sound better then a twopiece.
« Reply #7 on: August 24, 2013, 06:25:34 PM »
Personally I would start with the Chinese made 'Traditional Series' Tokai rather than the Chinese made Epiphone.  I've compared them side by side and the Tokai is far superior.  The Epiphone sells for around $450 here at the moment, the Tokai around $650.  See this page
http://www.harmonycentral.com/t5/Electric-Guitars/Tokai-Les-Pauls-differences-between-Japanese-and-Chinese/td-p/11055948
They mention the Japanese-made Grecos there too.  A friend of mine collects them and they are very nice instruments.  He has a couple of Greco SGs and a Greco Flying V (with Lace pickups)
I think you could get by with the BKP pickup and vintage harness upgrade I made for my Gibson Standard, maybe add Grover tuners if you don't like the ones it comes with and have a decent guitar for under £1000.  From the look of the fretboard the Tokai was much better than the Epiphone, so you probably wouldn't have to bother.
I have a Korean made Epiphone from 2006 but I wouldn't touch the newer ones.
« Last Edit: August 24, 2013, 06:31:42 PM by Agent Orange »
Nadz1lla
    • Arcanum Plectra
« Reply #8 on: August 24, 2013, 06:33:11 PM »
Again, what Tele said. There is a huge amount of factors to consider when looking at guitars, and don't forget that some things cost a lot more money just because they have a big brand name on them. For instance, I tried out an Epiphone Explorer that cost £350, then tried a Gibson Explorer that cost £1500. I MUCH preferred the sound of the Epiphone, it kicked the Gibson's arse, massively.
Basically all you need to do is take a day off, grab one of your guitars, and go to your local guitar store. Spend a lot of time switching between your guitar and trying a lot of stuff out in the store, and then if you want to buy something that feels and sounds better than yours, go for it.
I have to say, though, you seem to be going about it in a fairly backwards kind of way when you say something like this:
"I may buy an expensive guitar and over time realise how much better it is. But I just wanted to be prepared for it. "
I personally think this is completely the wrong reason to be buying anything. You could do that, then spend a lot of time trying to get used to it and then find out that it's not actually for you at all. To me, if a guitar doesn't immediately give you that tingle or improvement in tone or feel in the store that you've been looking for, then you should put it back on the hanger and move on to the next guitar. Never buy something and then "get used to it" or realise over time how much better it is, because if it is better, it should be immediately obvious. And if it is immediately obvious, and it's giving the results you really want, then it might be worth investing in. Parting with that amount of money for something that "may or may not" be better is way too much of a risk and largely a foolish thing to do.
I would seriously save your money mate, find out what it is you are looking for, not what other people say you should be looking for. If you're looking for a faster neck, a different tone, a different scale length, just something your current guitars don't do for you, then by all means listen to other people's opinions, but when all is said and done, it's you that has to live with whatever it is you buy, so it has to feel and sound right to your personal taste. Just go try loads of stuff out so you can build your own personal opinion of the things you like about them, then decide whether or not it's worth grabbing a new toy.  :wink:
Plenum n Heather
« Reply #9 on: August 24, 2013, 07:02:06 PM »
When I got my Tele Thinline a few months ago, the LAST thing I looked at was price and where it was made.
I went to a reputable dealer who has great setups and quality amps, picked the 3-4 Teles I liked the look of, and played around until there was a clear winner.
The entire process took about an hour. The price was good  (around 1k), the country of manufacture slightly surprising (Mexico), and I walked out with a Keeper.
Debating the pros and coins on a forum is a waste of time.
Turn off the computer, hit the shops, and make sure to bring a friend along to enjoy a celebratory pint with after your purchase. :)
Cam_H
« Reply #10 on: August 24, 2013, 07:07:43 PM »
Great advice. Cheers.
The main thing which had me scepticle was the Andy Timmons story. The Ibanez AT100 neck was based upon a cr@ppy neck he became very accustomed to, but he said that if Ibanez was to make a custom for him, no expense was to be spared on the material. That ending up in a £2k+ guitar. And its only basic wood as well. The neck one piece maple, etc. Nothing fancy. I was just sure there's something in a good quality guitar that I'm missing. But I guess I'll find that out when the time is ready.
Again, thanks for the advice :)
Nadz1lla
    • Arcanum Plectra
« Reply #11 on: August 24, 2013, 09:49:56 PM »
A lot of high-end Fender necks are one-piece Maple. ;)
Again, it all depends on the quality of the material, it was probably Uber-Grade Maple or something, heh.
It's all in the tiny, minute details. Quality of build, quality of base materials, if the pups are hand-wound etc. Get comparing low end stuff with high-end stuff and really focus on seeing how things line-up between the two, the quality of the finishes etc and get a true appreciation for a masterpiece bit of kit, then you'll be able to spot quality a mile away later on.  :)
« Reply #12 on: August 25, 2013, 01:47:58 AM »
I agree. The neck on my sunburst Fender Am. Series Tele is one piece. Fretboard edges are rolled, great twopiece straightgrained alder body and rosewood board, superb fretdress. Tuningstabiity and playability is topnotch. Gerat sustain too. You don't find that quality and feel on a Classic Vibe, that for the price is a well put together guitar that sounds quite mature. If money is an issue I wouid buy a CV and upgrade it a bit and BKP it. Then you got a decent stageguitar. If you can afford a USA Fender, try a bunch and pick the best one (as I did). Serves me for 13 years now with no problems.
« Reply #13 on: August 25, 2013, 03:32:21 AM »
I agree.  What I hate though is when you've blown all your cash on what you think is your dream guitar, then you go in the shop a week later and pickup one that you like better.  I had this 'tingle' when I first picked up an SG Classic, but I had already bought an SG Standard!  Still I got the horrid neck pickup tone out of that guitar (it had a 490R) by installing a BKP Cold Sweat.  The P90s in the Classic though are wonderful, although maybe not something I could use for everything.  Unless you want to be gassing all the time and collecting a huge pile of guitars (and going broke) often you have to settle for a workhorse that you can tizzy up a bit with a few mods (e.g., coil splits etc) to make it do all the things you want
I'd say the most important things are the basic tone of the guitar, balance, the number of controls (I hate those guitars with a master tone and volume for two HBs) and most importantly the feel of the neck. You can upgrade tuners and bridges later if you need to, but make sure that the basic design of all the hardware is what you want.  For example, don't buy a guitar that you will later have to route for different size pickups or a different bridge.
« Reply #14 on: August 25, 2013, 03:45:48 AM »
The neck is for me a major point in the selectionproces. The right thickness, frets and radius, good playability and feel. Another thing is that the guitar must have vibe, ergo a ringing/singing quality. But when I don't get on with the neck, I'm out.
