Author Topic: SSH guitars  (Read 25498 times)
Re: SSH guitars
« Reply #30 on: August 30, 2013, 03:28:21 AM »
I guess with humbucker-sized P90s an SG Custom could be made into any configuration of P90 single coils and humbuckers.  HSS, HSH, SHS, SSH, HHH, SSS.
SHS would be odd.
I've never played a three pickup Gibson but I'm guessing that the middle pickup might get in the way a bit
Re: SSH guitars
« Reply #31 on: August 30, 2013, 10:46:24 AM »
SHS would be odd.
I agree that the middle pickup gets in the way, but the biggest pain with three-pickup Gibson SGs and Les Pauls is the awkward wiring arrangement using the normal 3-way switch and pairs of volume and tone controls.  A three-pickup Gibson would be cool with more Strat-like wiring using a five-way switch.
bucketshred
  • Groovy
GREAT GOOGILY MOOGILY!
Zaned
Re: SSH guitars
« Reply #33 on: August 31, 2013, 07:43:11 AM »
Here's mine.
https://bareknucklepickups.co.uk/forum/index.php?topic=18963.msg255241#msg255241
Mind you, I have installed a resistor for both the middle and neck pickup, between the volume pot and the hot wire (IF I remember correctly). The effect is that the single coils see the volume pot as 250k, and the humbucker sees it as 500k. I got the advice directly from doing a search on this forum.
The guitar was brighter when it was brand new (sounds warmer and very balanced now, after a few years and lots of hours of playing) , and the SCs felt a bit brittle with the 500k pot. This was an easy fix and the cost was next to nothing.
HSS strats really are versatile instruments, especially when you get a pickup combination that works for you and the guitar. If I have to pick just one guitar for our cover set, this is usually it.
-Zaned
Paths are for followers.
Re: SSH guitars
« Reply #34 on: August 31, 2013, 07:36:35 PM »
-Zaned
I think that's a very important point- a lot of HSS (and HSH) guitars have very modern-sounding pickups, and I get the feeling a lot of people write them off as a style of guitar because of the pickups they've happened to try them with, which isn't really fair. (I get a similar feeling about high gain amps which tend to be paired with modern-sounding speakers and cabinets.)
Obviously that's not to say you still can't like them, but you might as well give them a fair shot at the same time.
