The Cold Sweat bridge is tight, bright and cutting but its relatively light wind means it sounds quite open to give it a bit of a vintage vibe.
The Holydiver is smooth, warm, thick and more saturated than the Cold Sweat. Very versatile with a nice 80's Metal feel to it. Very Doug Aldrich and Jake E. Lee. There's lots of mids there but it's a bit more balanced than it looks on the EQ chart. It's often compared to a JB but in reality, it's so much better it's untrue.
The Miracle Man should work fine in your guitar as the official BKP clips were done using a Les Paul. Like the Holydiver, it's smooth thick and warm and like the Holydiver, the EQ chart doesn't tell the whole story. It is scooped for sure but it isn't all highs and lows with no mids, it's just that a lot of the mids are low mids. As a result it gives you a big and articulate bottom end with screaming highs.
Another one you may consider is the alnico Nailbomb. This one is more about high mids. It's incredibly tight and aggressive sounding, with a real edge to the tone. Different to the others here but in mahogany, I think it might work well.
