Author Topic: Tubes  (Read 11514 times)
EffigyForgotten
Tubes
« on: September 14, 2013, 07:48:03 AM »
So right now my Bugera 6260 is loaded with JJ E34L's and i've been wondering what tubes you guys think are the "tightest" sounding, I also want to get more mid range "grind"
My favorite part about this amp is you can use practically any tube possible in any slot and the amp works, and does everything for you, just pop em in and play. I was thinking of getting 6550's or KT88's.
Re: Tubes
« Reply #1 on: September 14, 2013, 11:36:33 AM »
My experience with JJ's is that they sound quite round. The EH's I had, were more agressive in the midrange. If you want to stick to EL34's I would consider Svetlana's too.
No experience with 6550's and KT88's. Can't comment on that.
JJretroTONEGOD
  • JJ Retro w/Mule + BKP90
Re: Tubes
« Reply #2 on: September 14, 2013, 05:26:01 PM »
if you want midrange mullard are unbeatable, I think JJ valves are quite big sounding in the midrange compared to most.
tekbow
Re: Tubes
« Reply #3 on: September 14, 2013, 05:59:46 PM »
I think, and don't quote me on this, KT88's are midrange monsters, believe they're what goes into Kerry Kings Marshalls and what he's been using forever, but they do have a lot of headroom. then again he cranks all hell out of his amps.
http://www.youtube.com/watch?v=w6xk8T87tSE
Sounds grindy to me ;)
He also has a very tight sound I've always thought.
6550 is another Classic associated with Marshall tube apparently, but supposedly have a less prominent midrange.
Edit: Just came across this
http://proguitarshop.com/andyscorner/tone-tips-the-mighty-kt88
« Last Edit: September 14, 2013, 06:07:32 PM by tekbow »
EffigyForgotten
Re: Tubes
« Reply #4 on: September 14, 2013, 07:01:52 PM »
Yeah I think that link has made me decide on getting 2 KT88's to go with my E34L's!
Do KT88's have more headroom and tighter low end than 6L6's?
Right now my amp is all JJ's except one Tung Sol 12ax7 in V1, almost the same effect as a tubescreamer in front of the amp, although more subtle. I like JJ's thicker/darker tone, but sometimes I can't find a sweet spot for the high not to sound to dull or to harsh.
tekbow
Re: Tubes
« Reply #5 on: September 15, 2013, 09:52:25 AM »
Are you sure you can mix anything in there? I went and had a look at the specs and it says they're convertible from 6L6 to EL34. Now i know the tubes you're talking about are in the same respective families, but is there a section in you manual that says "anything from either"?
Tubes aren't just tubes, especially power amp tubes, a lot of them have different electrical specs (which fair enough, I'm not up on). Just advising a bit of checking first?
Re: Tubes
« Reply #6 on: September 15, 2013, 10:15:26 AM »
That was a sweet clip!  Besides the great sound, it reminds me that Venom wrote some of the coolest metal songs of all time.
tekbow
Re: Tubes
« Reply #7 on: September 15, 2013, 10:36:00 AM »
oh they were light years ahead at the time
https://www.youtube.com/watch?v=7GEbziEDL0s#ws
thread jack over, please go about your business ;)
« Last Edit: September 15, 2013, 10:39:22 AM by tekbow »
EffigyForgotten
Re: Tubes
« Reply #8 on: September 15, 2013, 05:12:10 PM »
Yeah, you cant run more than 2 though, and they have to be on the outer sockets.
Toe-Knee
    • DIY Audio
Re: Tubes
« Reply #9 on: September 15, 2013, 07:31:42 PM »
Do you have a link specifying this? I have a friend who blew his PT running correctly biased EL34s even though it was specified in the manual that the PT could handle the current but it turns out it actually couldnt.
http://WWW.BACKLINE.TK
Non Biased Guitar Forum
http://fret.boards.net
tekbow
Re: Tubes
« Reply #10 on: September 15, 2013, 07:42:19 PM »
Nasty.. how'd that turn out? covered in the warranty?
Toe-Knee
    • DIY Audio
Re: Tubes
« Reply #11 on: September 15, 2013, 07:52:02 PM »
Unfortunately it was well out of warranty. It was the second amp he had from them. He got one of the very first models that had the fire and smoke mods which is why he ended up with a replacement after sending it back a couple of times.
In the end i ended up fixing it a few times. It works solidly now but most of the original amp has been replaced.
I do hear that the newer ones are a lot more reliable however.
EffigyForgotten
Re: Tubes
« Reply #12 on: September 16, 2013, 07:09:44 AM »
Yeah, http://www.bugera-amps.com/EN/infinium.aspx
Mine is a 6260 Infinium 2013. Haven't had a problem with it for about 5 months.
tekbow
Re: Tubes
« Reply #13 on: September 16, 2013, 08:18:13 AM »
aahh, cool, bit like the orange DIVO system then
EffigyForgotten
Re: Tubes
« Reply #14 on: September 16, 2013, 08:28:30 AM »
Before I bought the 6260 I was trying to decide between a used 5150 and it, and the fact I can use any power tubes I want, kinda sold me. Only thing I don't like about the amp is the lack of an resonance/depth control.
I'm going to install an 81/85 set I have laying around in one of my guitars this week to see what happens. Gonna set it up in B/Drop A \m/
