NPD: Painkiller
Started by jc986, September 29, 2013, 04:08:27 AM
jc986
Hey everyone,
I just received and installed my first BKP, a Painkiller for the bridge of my PRS Singlecut.  My initial impressions are positive, although I'm still trying to figure out some type of polarity mismatch or phasing issue when both pickups are active (the stock neck PRS #7 and the Painkiller).  Both pickups sound perfectly fine when played individually, but in the middle position (both on) it sounds thinner and about 50% volume.
I haven't had a lot of time to really play with and locate the optimal pickup height, so I'll definitely do a more in depth review once I've given it a workout.
I am a bit surprised that it balances so well in volume when compared with the PRS #7 in the neck.  I have the neck pickup set fairly low, but I found myself needing to increase the height of the Painkiller higher than I had my PRS #7 bridge (DC resistance of 8.44k) set in order to match the volume of the neck #7 (DC is only 7.36k).
Pros:
The clarity is good, and the cleans are actually very solid, which I wasn't necessarily expecting out of an aggressive bridge pickup.  There is a definite spike in the upper mids, which I have to make significant adjustments on my amp to account for (this isn't necessarily a bad thing, it's what makes the pickup sound agressive and cut through).  The note separation under high gain is exceptional.  I typically tune to Drop C and it has no problems.
Cons:
Considerably lower perceived output than I was expecting based on the website description and various reviews.  Most other pickups I'm familiar with definitely seem to be higher output.  I have several Seymour Duncan's (JB, Custom, Distortion), a DiMarzio Dominion, and various EMG's.
I have to increase the gain quite a bit on my amp in order to get pinch harmonics as easily as my other guitars.
Cool that you like them, looking forward to the full review.
On the output, yeah, somewhat expected. When BKP says Hi gain it in general terms is more midgain compared to other manufacturers.
For one they actually are a little less hot, but it a lof it is the extra clarity which makes it seem like it is. BKPs are pretty uncompressed which makes em seem like that. Plus side is the extra amount of dynamics and clarity.
Plus if you are not going for a compressed sound you ususally are off better with a not stupidly high output PU when using todays amps.
