Author Topic: Changing Acoustic guitar string gauge... improvement?  (Read 4432 times)
5F6-A
« on: October 19, 2013, 08:31:34 AM »
This is my acoustic guitar:
auditorium size, 650 mm scale
not as heavy in the mids as a Martin 000, more European sounding I guess...
spruce top, rosewood back and sides, mahogany neck, ebony fingerboard, all solid.
lr baggs m1 + ibeam pickup system
I've moved from using 11-50 to 12-52 (Newtone 12-52. Double Wound Master Class. Roundwound),
Impressions:
- Action has raised from 2/32" to almost 3/32" at the 12th fret.
- Sound -and feel- is more "solid", there is slightly less zing to it.
- It requires a stronger strumming/plucking hand to get the notes ringing.
- Volume has increased (I think) slightly but not massively.
- The sound has morphed slightly from more "Taylor" to more "Martin" if that makes sense...
Overall, there have been a change. Is it for the better? I don't know. I'm leaving the strings to settle a bit for an extra 24 hours ( I DON'T stretch roundwound strings as this negatively affects their tone and lifespan) and give them a go again.
Anybody has had a similar experience??
« Last Edit: October 19, 2013, 08:33:29 AM by 5F6-A »
"I now consider atheism to be brutal because it offers neither consolation nor liberty of any kind" Benjamin Constant in 1804
"Practice until you can hear the metronome grooving" Carol Kaye
Keven
Re: Changing Acoustic guitar string gauge... improvement?
« Reply #1 on: October 22, 2013, 12:32:50 PM »
Bigger strings cause the soundboard to vibrate a hell of a lot more. personally i go for 13-56 for any acoustic i have to play on. sounds huge :)
My BK's:
C-Bomb Set / Blackhawk Bridge
Holydiver Set/ BG50 Set
5F6-A
« Reply #2 on: October 22, 2013, 03:16:10 PM »
interesting...
Plenum n Heather
« Reply #3 on: October 23, 2013, 02:12:19 PM »
I use silk & steels on my acoustic (Ovation Legend) and have only found them in one gauge, so I cannot answer this one! :)
