Quote from: Slartibartfarst42 on October 23, 2013, 05:04:29 PM
How would you say the Mule pickups compare to the Abraxas pups?
Here we go then a bit of a back to back comparison between an Abraxas and mule set.
Abraxas set are in a 2008 Lp standard, chambered body and pickups have covers.
Mules are in an 89 Lp custom and pickups are uncovered.
This is how things sound to my un-trained, tinnitus ridden ear holes.
Starting with the neck position, as per spec both pickups sound very similar. The mule sounds a touch brighter but that is probably due to it being uncovered. There seems to be more attack in the bass with the mule and overall more clarity. Again this could all be cover related.
Middle position. Both in very similar territory again but the weight and extra power of the Abraxas bridge give the middle setting a fuller sound where as the mule is more open and airy. Both sound great for a touch of setzer style rockabilly!
Bridge position. This is where things get quite different. The Abraxas is a lot thicker and richer sounding compared to the mule. Dare I say it, but the Abraxas almost sounds a bit on the muddy side when put in direct comparison with the mule. I've been using the Abraxas set for over a year now so I know it doesn't lack clarity, but when it's put up against its lower powered cousin, I think the mule shines through as being more harmonically rich and way more open sounding. Goes without saying that the Abraxas has more gain and gets more saturated than the mule.
I think there will be a Fair bit of pickup shuffling going on over the next few months and i can definitely see the mule bridge replacing the Abraxas for a while.
Hope my limited vocabulary was descriptive enough and made some kind of sense!
