Wiring help needed, HH/1vol, 1tone/5-way super switch/Ibanez style switching
Started by silence2-38554, October 30, 2013, 06:04:40 PM
silence2-38554
Hey everyone, I need some help wiring up my BlackHawks.  Basically, I'd like to wire them according to this diagram:
https://bareknucklepickups.co.uk/main/downloads/schematics/general/humbuckers/2_hum__ibanez_style_5_way_switch__1vol_1tone_.pdf
But with a super switch rather than the cheap "import" style switch.
Thanks!
Guitarteach
There are a bunch of wiring diagrams here:
http://www.guitarelectronics.com/c=Gk5saC9fmX2KCE4nFOukfN28X/category/wiring_resources_guitar_wiring_diagrams.2_pickup_guitar_wiring_diagrams/
I am mid project with an Ibanez HH guitar to do same with a Superswitch. I want to avoid the magnet turning the original wiring required too.
Got a few guitars - old to new and Boogie kit.
BKPS: Rebel Yell, Holydiver
Love old valve amps... But then I am biased!
silence2-38554
Quote from: Guitarteach on November 01, 2013, 09:06:50 PM
I ended up using this diagram & everything works perfectly.  I just re-labeled the DiMarzio wiring to match the BKP colors.  You also shouldn't have to flip the neck pickup for correct IBZ wiring:
timmy_b
This wiring scheme may well work in-phase, however the only way to have the inner coils of the bridge and neck working together AND hum cancel is to reverse one or other of the magnets.
EDIT.. Although, if you have Blackhawks, the coils are symmetrical, so which coil you make the 'inner' is fairly irrelevant, so you can simply flip the orientation of the neck pickup around and reverse some of the wiring to give you access to the polarity-correct coils for those positions.
Hi all, yes, it's another Tim! I'll be here to answer any questions you want to throw at me, here or via [email]sales@bareknucklepickups.co.uk[/email]
megaup987
Instead of starting a new thread I'm going to hijack this one as it's kind of related.
Wiring the schematic like this: https://bareknucklepickups.co.uk/main/downloads/schematics/general/humbuckers/2_hum__ibanez_style_5_way_switch__1vol_1tone_.pdf
Can I solder the black and bare wires of the bridge and red and bare of the neck pickup to the case of the switch (instead of the back of the pot)? I guess it shouldn't matter as the case of the switch is grounded to the pot case anyways. I just don't to have weird ground loops.
Thanks.
silence2-38554
Quote from: timmy_b on November 11, 2013, 10:18:36 AM
Could you please elaborate on which wires would need to be reversed if the neck pickup were flipped?  Currently, I have them wired exactly like the diagram above, with both pickups' wiring exiting toward the bridge.  I recently read that the "standard" orientation for the neck pickup is to have the wiring exit toward the neck, so I'm guessing that it's already technically flipped?
