Author Topic: best metal humbucker for an alder strat with maple/rosewood?  (Read 9162 times)
littleredguitars2
Re: best metal humbucker for an alder strat with maple/rosewood?
« Reply #15 on: November 06, 2013, 06:45:12 PM »
How does the situation look like with HSH with set of Juggs and TS in the middle?
What would you recommend, plain middle TS or with the baseplate? Stock wound or RWRP?
I`ve also read somewhere that some people would in that case put NECK single coil in the middle possition to give it more smoothness and match it with set of humbuckers.
we`re talking about metal/proggresive metal type of music.
cheers
I'd have to route out the wood to fit another humbucker
yeah, I know that, but I was asking about my case with old Ibanez copy guitar and HSH configuration. :)
Oh I gotcha! Yes I'd say that would work really well
Lucas
« Reply #16 on: November 06, 2013, 07:23:46 PM »
but which version of middle TS would suit the best with Juggs set?
Plain middle TS or with the baseplate? Stock wound or RWRP?
littleredguitars2
« Reply #17 on: November 06, 2013, 09:20:38 PM »
If I were you I would put a neck TS with a base plate personally.  I like the neck pickup much more than the middle
« Reply #18 on: November 06, 2013, 09:34:13 PM »
You have a few guitars with just the one HB slot yeah?  Probably not a bad idea if you don't find the TS such a good match.  The Juggernaut is the lowest output bridge pickup in the contemporary line (besides the Black Hawk) so it should be a better match if you find that the Stockholm is a bit hot for them.
I'd put the Stockholm in that nice looking black Strat with the stripe on it. The Stockholm is very well suited to a one pickup guitar.  To get the most out of it though I would add a tone pot to that guitar.
Just saying, out of all the high output BKP's the Blackhawk is actually probably the hottest, if you compared it to the Warpig it would just sound louder and have more power to every note you hit.
Well, that's why I sort of put it in brackets because the resistance figure doesn't seem to give a good indication of the output we hear.  The Juggernaut on the other hand seems a more conventional design (besides the magnet mix) so I figured comparing with the Painkiller and Aftermath in terms of those figures might be more reliable.
On the other hand I don't trust comparing P-90s and Fender single coils with humbuckers in those terms.  P-90s always seem to be at least as high as a humbucker of the same rating whereas the Fender style ones do not.
Lucas
« Reply #19 on: November 07, 2013, 10:10:50 AM »
is that configuration common? Is putting neck single coil into middle possition well practised? I`ve read it somewhere but don`t have much more information.
thanks.
« Reply #20 on: November 07, 2013, 10:51:12 AM »
I assumed that they were the same pickup and they just sounded different because of where they are located relative to the strings.  The output is the same, right?
Lucas
« Reply #21 on: November 07, 2013, 11:36:27 AM »
output is the same, indeed. What about wiring, would that be the same as well? If yes, they are the same pickups then.
littleredguitars2
« Reply #22 on: November 07, 2013, 12:29:35 PM »
Definitely something I would ask ben or Tim. I personally don't think a couple inches would be the only thing that changes the tone so drastically between the neck and middle pickup
« Reply #23 on: November 07, 2013, 01:30:14 PM »
Your middle might sound different because it is RWRP.
Personally I would have gone with stock wound, as in most positions the hum will be there anyway.  Like most Gibson players I rarely play between positions ... I guess Fender guys are used to it though
« Reply #24 on: November 07, 2013, 02:38:06 PM »
Well - in my experience it really does. I have swapped neck and middle pickups to achieve the desired humcancelling combinations in at least two guitars and have not noticed a difference in tone of the individual pickups (these were not BKPs but I believe the results with BKPs would have been the same).
BTW I am not really a middle pickup player and much prefer the neck or bridge pickups.
Going by specs it appears that neck and middle pickup are the same in each SC set but in the end only the BKP team can give you positive assurance on that.
