Author Topic: Which Bareknuckles to have in all mahogany guitar for versatility ?  (Read 5742 times)
ProggLife
Hi guys,
I use a Chapman guitars ML3-RC (Picture attached) it is a Tele style body but it's a mahogany body, mahogany neck and rosewood board with a set neck. It comes with seymour duncan single coil sized humbuckers in both positions and they are coil tappable, I love the sound at the neck but the bridge doesn't quite do it for me. I am getting a new bridge fitted that accommodates a full sized humbucker and I am sure on a bareknuckle just not sure on which of the contemporary range to go for. I play everything from coil tapped cleans, bluesy low to mid gain break up, really upper mid rangy tight modern metal and all variety of lead sounds. I am looking for something versatile that can handle all of those styles convincingly and also give a slightly more open sound to a quite dark sounding guitar.
Any tips and advice are appreciated.
Cheers
Sam
Hendrix-HK
  • BKPs: black dog / RY
    • www.hendrix.to
Re: Which Bareknuckles to have in all mahogany guitar for versatility ?
« Reply #1 on: November 23, 2013, 04:48:44 PM »
I put a  'Rebel Yell' humbucker  on a bridge of tele too , it not so dark , I think it would work for you .
https://bareknucklepickups.co.uk/forum/index.php?topic=30917
GuitarIv
« Reply #2 on: November 23, 2013, 04:51:59 PM »
Rebel Yell without a second thought. Slightly vintage in character with a modern voicing, very reactive to pick attack and the volume and tone pots + tight lows and focus in the high mids.
Can go from this:
http://www.youtube.com/watch?v=S_tnOFRowug
Over this:
http://www.youtube.com/watch?v=20zSjw98Gvg
To this:
http://www.youtube.com/watch?v=GaFeG6vLbR0
Everything you hear in these clips is done with the RY.
Hope that helps, cheers
ProggLife
« Reply #3 on: November 23, 2013, 05:07:28 PM »
Thanks for the replies guys, the RY was actually one I was definitely not considering so thank you  :D I am actually a Red Seas Fire fan and had no idea they were rebel yells thanks !
richard
« Reply #4 on: November 23, 2013, 06:12:35 PM »
Played a gig last night with my Firebird Studio (all mahogany, rosewood board) fitted with a pair of RYs. I go through a Cornford Roadhouse which has a Marshall character to it. When I gig with this set-up I don't want to stop playing. A match made in heaven. As much punching drive as you want and cleans up great with the guitar volume. I'm sure you won't be disappointed.
PRS S2 Singlecut RY's
JV Strat  IT Bridge
Gibson SG JB bridge
Fender Bassbreaker 15
Yamaha THR 100 Dual
Quilter Aviator Cub
ProggLife
« Reply #5 on: November 23, 2013, 06:18:42 PM »
Sounds good man thanks, my only concern with the rebel yells is if they'll do the modern metal thing well, I'm avoid that word but 'Djenty' ahaha
« Reply #6 on: November 23, 2013, 07:22:25 PM »
riff raff should work really well too
 8)
Heket
  • BKPs: Rebel Yell bridge
« Reply #7 on: November 23, 2013, 09:03:12 PM »
Rebel Yell! I put one in my all mahogany set neck SG and it does exactly what you describe. I'm not sure about djent though, the sound is very tight but the key players are the upper mids and highs. But I'm sure you can work that out with your other gear. I'm not sure any other pickup will do as many things as you are describing, except the C-bomb maybe, as that was also recommended to me by Ben.
« Reply #8 on: November 24, 2013, 02:33:06 AM »
Rebell Yell should work fine.
GuitarIv
« Reply #9 on: November 24, 2013, 06:21:51 AM »
Again, sound does the talking the best:
http://www.youtube.com/watch?v=3QGpa_HOsbU
http://www.youtube.com/watch?v=P-ppjENE6J8
You should be fine with the RY ;)
  • Random Solution
« Reply #10 on: November 24, 2013, 09:12:24 AM »
If you don't fancy the Rebel Yell, you might want to consider the Nailbomb as an alternative. The A-Bomb is usually suggested by BKP for great versatility and although its mids are a little lower than the Rebel Yell, I certainly never found it lacking in upper mids. Try looking at these Sam Coulson clips, all done with an A-Bomb set:
http://www.youtube.com/watch?v=G6AsHu3Q5zM
http://www.youtube.com/watch?v=9pGQbZQfhMo
http://www.youtube.com/watch?v=VKkMxJiCjTU
« Reply #11 on: November 24, 2013, 12:32:30 PM »
Shocker incoming....Rebel Yell! Just works =)
BigB
  • Let's rock !
« Reply #12 on: November 24, 2013, 07:17:22 PM »
ABombs do work fine for me in my dark SG, and they have incredibly tight lows for Alnico pickups, now as other members already mentioned they are more about center/low mids where the (slightly less hot IIRC) RYs have more of that upper-mid bite - not that the Abombs have any problem cutting thru a dense mix, don't get me wrong. But anyway: your post looks mostly like a description of the RYs so that would my first call, with the ABombs as a second choice if you finally want more of that throaty low-mids ROAR (while still getting enough upper-mids aggression to cut thru).
