volume(guitar) on full by the time it reaches no 2
Started by monkeywalker, March 11, 2006, 07:42:18 PM
monkeywalker
the volume pot on my guitar isn't working properly, the volume goes on and off very suddenly when you turn it. it's on full wack by the time you reach no 2.
i replaced the volume pot with a new one, and also i replaced the capacitors and some of the connecting wires with higher grade ones.
does anyone know why i am still having the same problem with the volume pot?
any suggestions would be appreciated
sambo
cant help mate but i suffer from the same thing- theres very little volume change from 10 to 2 then it suddenly cuts it all away... quite annoying...
Spleen
Are you guys playing Gibson style guitars?  If so, this is pretty common, they don't have a very good roll off at all.  My gibson goes from zero to about 70% volume between 1 and 2.  I have a tele that rolls smooth all the way from 1 to 10.
monkeywalker
yea, mine is tokais copy of the SG, the thing is, i didn't have this problem until i installed the new pup, i don't know if i've done some damage to a component somewhere that i can't find.
and besides, even if it is a common problem surely it should be rectifiable.
sambo
yup mines a gibbo.... but like monkey said- surely its fixable?
Kilby
Goodbye London !
sambo
if i knew what they were i could answer you....
but a guitar shop did mine so im guessing that they did know what they were doing..... although it was machinehead....
jimi hendrix
Quote from: samboif i knew what they were i could answer you....
http://www.guitarelectronics.com/category/wiringresources.1basicwiringfaqs/#q2
check this out for some info
sambo
monkeywalker
yea i used an audio taper, aren't you only supposed to use linear for tone as apposed to volume. i believe that most companies use audio for both volume and tone anyway.
my ibanez has this problem ; i never really thought about it as a problem before though. who actually uses their guitar's volume for volume? i just use it for controlling the output of the pickup - and weather i want it dirty or clean
monkeywalker
yea same here indy but it doesn't even do that anymore, its just full. its well gay.
