Hi,
When trying to work a little bit around coil splitting and other funny stuff, I found myself stuck: there is something I do not understand...
Here is what I get about hum cancelling:
- Inverting the polarity (north/south) will invert the response to the strings motion, but not the hum.
- Inverting the wind (inverting the direction of rotation of the wire, or the start/finish connections) will invert the response to the strings motion and the hum.
- The two coils of a humbucker have opposite pole and wind, to have in-phase responses to strings motion, but opposite hum. This is how hum cancelling is done.
Now, here is what I understood about the humbucker conventions, and I may be totally wrong:
- For both bridge and neck humbuckers, the coil with screws is the south pole, and the slug coil is the north pole.
- Screw coils are set at the extreme positions: near the neck and near the bridge. Thus we basically obtain for the four coils: South-North – North-South.
So, in standard configuration, I assume that for not having phase-inverted responses from the humbuckers, south pole have the same wind.
All these data are summarized on the drawing bellow.
Now what I do not understand is this: in many sources, I found that when coil splitting, if I want to keep hum cancelling when both pickups are active, I need to keep either the two internal coils, either the two external ones... But, with what I explained before, I get that those coils have same polarity and same wind... So combining them would not cancel hum.
Please, your help will be very useful. I just cannot find my error. Did I miss something?
