Author Topic: Neck pickup not working correctly  (Read 4216 times)
Shortie87
« on: December 19, 2013, 04:04:51 PM »
Hi guys, hoping someone can help as this is a new one on me...
I've got an Ibanez rg 1451 which I've installed a set of nailbomb and an Irish tour in a couple of months ago.  All has been fine since then, and they sound great, up until about 5 minutes ago...
I've just switched to the neck pickup and it has basically no output. You can just about hear something, but barely. All the other positions on the 5-way work fine.
The guitar hasn't been apart, just played, and it worked great about an hour ago...
Any ideas?
Skilpad
  • Riff Raff N, Cold Sweat B, on ESP Eclipse II
Re: Neck pickup not working correctly
« Reply #1 on: December 19, 2013, 07:53:07 PM »
Dead switch maybe?
You shall test that every contact is ok (in particular for the switch: check that contacts are done when (and only when) required).
When you are using both PUs, does both work? Or only the bridge one?
« Reply #2 on: December 19, 2013, 09:39:16 PM »
bad solder joint?
Shortie87
« Reply #3 on: December 19, 2013, 10:32:43 PM »
Skilpad - if I put it in the split position (neck and middle) it seems to work ok, and sounds as expected.
Agent Orange - I wouldn't have thought so, as they've not been in long, and I soldered all the joints myself, so they should be decent at least. I was planning on taking them out and wiring in some coil taps anyways, so I guess this will come to light then, just wanted to check it wasn't the possibility of being the pickup itself?
« Reply #4 on: December 19, 2013, 10:55:28 PM »
The most likely culprit is a faulty switch.  I know I had problems with the toggle switch on my Explorer a few months after installing the Warpigs, possibly aggravated by the fact that the switch had been out, moved around, etc
Shortie87
« Reply #5 on: December 19, 2013, 10:57:10 PM »
That wouldn't surprise me, I'm still using the cheap, stock Ibanez switch. I have a vlx91 here that I'll need to put in when I'm rewiring for the coil taps, so we shall see I suppose!
« Reply #6 on: December 20, 2013, 12:33:06 AM »
Yeah I had the cheap Epiphone toggle.  Replaced it with Switchcraft.
metale
« Reply #7 on: December 20, 2013, 07:50:44 AM »
MIK Epiphone? In my experience, Korean Epis had worse electronics (especially switches) but better fit and finish than current Chinese ones.
« Reply #8 on: December 20, 2013, 08:58:16 AM »
Yes, it's one of the last MIK Explorers (2006). The finish etc is good but the electricals have been completely replaced by Mojotone CTS, Switchcraft, and Bare Knuckle components, with a custom made fully-shielded harness and fully-shielded cavities and pickguard.
« Reply #9 on: December 20, 2013, 11:58:53 AM »
Indeed this sounds (no pun intended) like a faulty switch.
