dilemna- to strip or not to strip?
Started by sambo, March 12, 2006, 09:20:47 PM
sambo
ok the subject isnt qutie as exotic as the title suggests- its talking about my melody maker- as some of you may know i really wanna customise it in some way and my latest plot is to strip it down to the reveal the natural beauty of the lush mahogany...
never considered this before but the *REALLY* thin coat of cr@ppy ronseal or whatever it was that Gibson must have used on it has started to wear off in certain places... im starting to see little areas of AMAZING, lush, orangey/browny/red grain underneath the black gloss and its oh so tempting to just whip out the ol' sander....
what do we think? my super-distressed BKP-92 matches perfectly with the black of the MM at the moment but i think it would match with the true orangey kinda colour of the wood as well....
ill try and post some pics of the tiny areas that are being revealed soon but the quality will be cr@p and the real beauty wont be conveyed wel at all...
so in the mean time, in theory- strip or dont strip?
Strip it, its gotta look better than that cr@ppy ronseal finish  :lol:
Kilby
Have a word with Ron2e or Feline about stripping.
Sanding is not the way to go about it unless you want a reshaped guitar.
I assume with it being a set neck that you will also be stripping the neck, which means being doubly careful.
Rob...
Goodbye London !
sambo
mm indeed the neck shall be stripped as well.... so what do you do if you dont sand then???
use it, abuse it, let the red shine thru - ronseal finish sounds pretty nice to me anyways. finishes that come off are the best!
Kilby
Theres chemical strippers, and heat stripping.
My ibanez / antoria SG was ftripped using nitromors (spelling ?) but it was a bolt on neck so I didn't have to worry about the neck joint.
Theres (or there used to be) two versions of nitromors one you removed with water and the other you removed with meths  (wood alcohol to you US people, I don't mean crystal).
If it's still available I would suggest the meths version as water can cause the grain to raise (so I'm told).
Once again theres a couple of luthers with sheds of experience, who will be able to point you in a reasionable direction.
Rob...
Goodbye London !
R/2e
Yes, certainly Nitromors for stripping, just make sure you clean off the residue properly afterwards. Sanding is a no-no unless nothing else works. After the Nitromors I use thinners and steel wool with lots of mopping with kitchen towel.  Before you start though, what year is it? It's not advisable to mess with a vintage guitar as it really hits the value. Having said that, and if you want to go ahead, the best finish in my opinion is what you describe as "the *REALLY* thin coat of cr@ppy ronseal ", or nitrocellulose lacquer as it is more commonly known and which Gibson still use!  Taking the point that yours is finished in a solid colour I would suggest , if the grain is as good as you say, stripping back to the wood, use a dark (Rosewood or Walnut) thixotropic pore filler, red stain, then clear lacquer on top. This gives the stunning 60's Cherry Red finish with the grain showing through. If you need any further info on this, drop me an email.
sambo
Quote from: R/2eYes, certainly Nitromors for stripping, just make sure you clean off the residue properly afterwards. Sanding is a no-no unless nothing else works. After the Nitromors I use thinners and steel wool with lots of mopping with kitchen towel.  Before you start though, what year is it? It's not advisable to mess with a vintage guitar as it really hits the value. Having said that, and if you want to go ahead, the best finish in my opinion is what you describe as "the *REALLY* thin coat of cr@ppy ronseal ", or nitrocellulose lacquer as it is more commonly known and which Gibson still use!  Taking the point that yours is finished in a solid colour I would suggest , if the grain is as good as you say, stripping back to the wood, use a dark (Rosewood or Walnut) thixotropic pore filler, red stain, then clear lacquer on top. This gives the stunning 60's Cherry Red finish with the grain showing through. If you need any further info on this, drop me an email.
what if.... more and more starts to wear.... then i have the cash for the jobby of stripping+re-finishing we discussed AGES ago.... is it still effective? i.e... what if nearly all the black finish has gone but some still remains? or what happens to the slightly exposed parts when you strip the finish? anything?
BTW, its a new melody maker, 2001/02 i think... not a vintage so im ok there.... plus ive already replaced the pickup which would probably hit the value anyway...
blue
yes, but by the time you grow up it WILL be vintage!
the finish on those guitars is weird, i imagine it looks kinda cool worn.  why don't you put up a picture?
Bainzy
So Ronseal is actually nitrocellulose paint...?  :lol:
Searcher
Not that I wanna argue with R/2e, who I'm sure knows more about finishing guitars than I do, but I've successfully sanded back a guitar without reshaping it. I used an orbital sander to get the stuff of the flat areas on the front and back of the body and did the rest by hand.  I did the neck entirely by hand.  I used 80 grit sandpaper, then 180, then 320.
It did take ages though.  Nine hours of constant sanding, to be precise, to get through a huge build-up of epoxy.  So this isn't necessarily a recommendation; I'm just saying it can be done without any damage if you're patient.  I would estimate your guitar to be do-able in less time though.
sambo
cool thanks mark...
haha yeah Rich...  :lol:  :lol:  :lol:
and Blue ill get a pic up A.S.A.P... but i have absolutely shitee camera so it wont come out too well... but yeah it looks cool....
I would say that only strip it if you really really want it stripped because, although it is not vintage now, it will be one day-just be sure before you strip it.I would also take on board what Ron says- he knows his onions. Thats me done.
sambo
yer i see what yuor saying mr.beatle....
but then in however many years time.... when its vintage... the finish will be ridiculously worn anyway....
i think...
i dunno
Eew!
I'm not keen on Nitromors - not because it's not gopod but it can be messy and get on your hands etc
I tend to use a heat gun and cabinet scr@pers myself.
And I agree that sanding needent do damage or reshape- depends on the skill and patience etc of the person sanding
However I feel that having a COMPLETE plan of action from strip to reseal / finish is needed and fully implimented rather than just going at it haphazardly
I don't like guitars being semi-stripped and played with the intention of putting a new finish on at aa later datre as the wood gets very dirty and contaminated with stuff that may stop a futeure finish from sticking.
See my previous thoughts on WD40 for more on that subject
