Volume taper issue
Started by Krisrichmnond, January 08, 2014, 10:55:26 AM
Krisrichmnond
I'm after some advice..
I have Mule neck and Riff Raff bridge, 2 conductor with a push pull tone and volume bypass switch (on tone control), audio taper volume pot.
The volume control did all the changing between 10 and 8, I thought this was the affect of the treble cut from the volume pot, so I installed a treble bleed.  Now the volume control only does anything between 0 and 2,  and it's left me scratching my head.
Anyone have any ideas on how I can improve the sweep of my volume pot?
gordiji
if it's a log taper swap it for a linear taper & vice versa. they sell 'em at bkp.
Krisrichmnond
Really?  A log taper in the volume pot?  I dont understand why I would want that
King Zog of Albania
Almost all volume controls are log taper.
If you're in a mood to experiment with tapers then you can get a 500k lin pot and put a 500 kohm resistor across it and it becomes a less linear 250k pot.
And if you're in a mood to experiment with tapirs then you should probably go to the zoo.
