Author Topic: Best Pickup to play heavy pop/punk & great cleans in schecter diamond series  (Read 5696 times)
righteousrock8
Hey everyone! I'm buying new pups for my schecter diamond series. I play Heavy pop/punk music and am wondering what's the best pickup for it? I'm going for a These Hearts, Chunk No Captain Chunk kind of sound. I also have a coil splitter I'm installing for more versatility as i also play worship music at my church too with this guitar. Ive been thinking about the painkiller because it claims to have all the clarity, tightness, full heavy sound but also clean up real nice. And it will look sick in my blue schecter. Thoughts??? Thanks in advance!!  :D
Yellowjacket
What does the guitar sound like unplugged?
righteousrock8
What do you mean? It just sounds like an unplugged clean electric sound. The stock pickups are decent but i just want more clarity and a little more output but still be able to be versatile
Well opening up a second thread will likely not help....
Anyhow, what is meant is that electric guitars all have different basic acoustic sounds to them. Since these have an affect on what the pickup recieves this is very important. In Les Pauls alone there is a wide range from the fat dark sounding ones to middy to thin. Not to even speak of guitars with other build styles or woods.
So if you have any point of comparison with another guitar listening to those would help us along a good bit.
If the guitar for example is on the fat and dark side I am inclined to recommend the Rebell Yell (although I am only going by what I think of the style, not by the bands you name as I am unfamiliar).
Easy answer will be:
In no particular order.....
Mississippi Queen
Mule
Riff Raff
VH2
Mississippi Queen
Mule
Riff Raff
VH2
+1 Yep as always Feline has great ideas. All these could work wonderfully depeding on the wood, acoustic sound, and rest of the gear.
righteousrock8
Sorry for the second thread. Its got a maple neck and basswood body, stock pickups are overwound ceramic schecter pickups. they sound good but i want a bit more out output and clarity. I have the right gear for high gain and clean playing including a blackstar head and orange cab, a peavey classic 30 and some various pedals. Unplugged the guitar sounds very full and resonates very well actually. A bit more emphasis on the mids and highs then the bass it seems but its still not lacking it. Im looking for a pickup that looks like the classic covered humbucker (painkiller, Nailbomb etc..). Thanks for the help though guys!
This might be a job for the Cold Sweat set.  If you want something that will clean up nice I'd go for that before the Painkiller set.
Out of the neck BK pickups I've played the Cold Sweat, Emerald, and Nailbomb all provide great cleans.
The Warpig does not.  As you go higher in output neck pickups tend to sound overdriven when 'clean'.
Yellowjacket
Well, as mentioned earlier in the thread, each guitar has it's own acoustic sound unplugged and no one guitar sounds alike to another.
Here is an example I uploaded in another thread.  The first guitar is a 24 fret 24 3/4 scale mahogany body and neck, with a bolt on neck and rosewood fingerboard.
The second is a Les Paul, 22 fret 24 3/4 scale mahogany set neck with a weight relieved mahogany body  (They drilled holes in it), a maple top, and a rosewood fingerboard.
https://bareknucklepickups.co.uk/forum/index.php?topic=31283.msg402937#msg402937
I would guess that a basswood body / maple neck would most likely yield a brighter tone than either of these guitars.
How is your guitar currently set up?  How high are the pickups?  You can raise output by raising the pickups so that they are closer to the strings, this also decreases string definition which is why you want BKP.
The overwound Ceramic pickups are the C-Pig  (Ceramic Warpig) and that would give tonnes of output and split nicely but wouldn't work so well for church music.
I have two different amps, a Dual Rectifier which I have used for heavy punk pop tones / metal tones now, and a Mesa Boogie Electra Dyne which works well for church music.  They're both very different amps, especially in terms of frequency curves and response.
The Recto is dynamic for a high gain head but it is terribly compressed compared to the Electra Dyne.  The Electra Dyne is very dynamic i.e.  play quiet and get clean / play hard and get crunch.  I find what works for one style is really a compromise for the other and it is often a very frustrating balancing act.
Now, you're not playing metal so here's the thing:  I've dialed in a great punk / pop tone on both my Electra Dyne and my Recto.  With the recto, I dial BACK the volume knob to reduce output on my Rebel Yell.  This gives that nice round, smooth, and complex crunch tone i.e. that 'BAAWWW BAWWW' sound used for punk.  As I turn the output up, the amp gets much hairier and starts to sound more nu - metal, or vintage Death Metal.
I've gotten punk - ish tones from the stock pickups in the Les Paul as well as a Seymour Duncan Alnico II Pro bridge pickup.  The lower output pickups are often sweeter, more dynamic, and crunchier than the high output ones are.
We're talking very different guitars than what you have, so do bear that in mind.  That aside, the 'punky' tones on the Electra Dyne are with the mids slightly scooped and the volume  (Gain) up quite high on 'Vintage High Gain'.  Vintage Low does more vintage tones while the Vintage HI sounds more modern, like a Roaring Marshall.
Two different amps, two different approaches, similar results.  The Recto does sound more MEAN and is probably closer to what you're going for.
The Painkiller is an overwhelmingly upper mid heavy pickup, at least according to what the website says.  I would hesitate to use it in a maple neck / basswood body guitar as it would probably sound very bright.  Again, compare YOUR guitar to the two guitars I recorded.  The first is very dark with a focus in the low mids, the second is very mid mid focused with phat lows that are not overpowering.  It has an 'acoustic guitar' resonance to the sound.
IF you want a tight, clear, and powerful bridge pickup, there is always the Warpig.  That will provide a phat and overwound sound with huge lows, but it might not be as versatile as you would like.
To give you an idea of which bridge pickups I'd match with my two guitars.  The first one  (THe GOdin LG) would most likely take a Rebel Yell or a Painkiller.  The Second  (Gibson Les Paul) would take a Nailbomb and, in fact, I have one on order right now.
As I say to everyone, email Ben.  BKP has great service and he can help nail down what you're looking for.
