For a Santana meets Trey Anastasio tone...
Started by Lizard on Ice, March 15, 2006, 02:21:40 AM
Lizard on Ice
How would an Abraxas in the bridge and an Emerald in the neck sound?  I am in the planning stage of building a Warmoth guitar, and it will be a Koa Semi-hollowbody with coil taps.  I'd like a warm Sanatana lead tone with enough mids to stay bright and crunchy when I roll off the gain.  Thanks.
Mother's Milk set
carlaz
Man, first somebody looking for Garcia tone, now this ....
Quote from: Lizard on IceHow would an Abraxas in the bridge and an Emerald in the neck sound?  I am in the planning stage of building a Warmoth guitar, and it will be a Koa Semi-hollowbody with coil taps.  I'd like a warm Sanatana lead tone with enough mids to stay bright and crunchy when I roll off the gain.  Thanks.
Welcome to BKP, jam-loving brothers! :)  Anyway ....
For Santana tones: Abraxas. 'Nuff said!  As for Trey, he uses Schaller Golden 50 pickups, which as I understand it are supposed to be very PAF-like (~8.2k in the bridge and ~7.4k in the neck, I believe).  I'd not hesitate to pick the Mule as an appropriate BKP here.
Honestly, I think you'd probably be good going with with either a Mule set or Abraxas set.  The Abraxas is, as I understand it, voiced much like the Mule, only hotter than a true PAF-style.  It's like a "Mule+".  For another, option: If I recall aright, Trey uses the neck pup a lot for cleaner sounds, so you could put an Abraxas in the bridge and a Mule in the neck.
Either way, I think a Mule or Abraxas in the neck will get you closer to where you want to go than an Emerald in the neck.
When I was choosing pups for my LP, Trey and Santana tones were two of my major touchstones.  I also wanted the ability to take my sound up into a more metal zone, doing Iommi and Kyuss and Roy Z kind of tones, so I went with a Crawler set.  A Crawler neck is actually the same as an Abraxas neck (and I need those Santana neck tones!), but the bridge has a bit more grunt and midrange; it's got vintage vibe but is moving a bit further of that feel than the Abraxas.  But if I were Trey, I'd get Mules; if I were Santana, I'd get Abraxases.  I think a set of either or a combo of these is what I'd consider in your case.
Tim
Not sure I'd put an Emerald in the neck, it'd be too thick sounding(assuming you're on about the emerald bridge).........an Emerald neck however would be fine, it's stil AV but a more open wind.
Tim
Quote from: TimNot sure I'd put an Emerald in the neck, it'd be too thick sounding(assuming you're on about the emerald bridge).........an Emerald neck however would be fine, it's stil AV but a more open wind.
I don't think that's very clear to us......
I think you mean an Abraxis set??
What Tim is saying is that you should use the Emerald Neck pickup from a calibrated set in the neck position.  If you just order an Emerald, you will get the Bridge pickup, which is not a good pickup to use in the neck position.
carlaz
How does the Emerald neck compare to the Abraxas and Mule necks?  I think the Product Description pages still have just bridge statistics.
