Author Topic: Need wiring help/tips for single coil split with 2vol/ 1 push pull pot.2 humbuck  (Read 5347 times)
RosettaStoned
I got my BKP MM today, and im gonna begin soldering now. But the wiring diagram i got from BKP has 3 push pull pots. Does anyone have the diagram for 1 push pull pot with single coil split? Its a ESP eclipse II with 3 pots. the pickups are a bill lawrence and a Miracle Man. Split coil function
« Last Edit: February 01, 2014, 02:37:35 PM by RosettaStoned »
RosettaStoned
Re: Need wiring diagram for single coil split with 1 push pull pot.
« Reply #1 on: January 31, 2014, 05:25:48 PM »
Any one? i got some issues with the diagrams i got.
« Reply #2 on: February 01, 2014, 01:46:18 PM »
There are a heap of different wiring diagrams that you can download from the BKP site.
The diagram you have has three push-pull switching pots???  That sounds odd.
Are you trying to split the bridge, neck, or both?
RosettaStoned
« Reply #3 on: February 01, 2014, 02:23:29 PM »
https://bareknucklepickups.co.uk/main/downloads/schematics/general/humbuckers/2_hum__2_vol__1push_pull_tone_coilsplit__3_way_blade_switch.pdf
here are my questions:
*Where do i solder ground? i solder the grounds to the top of the pots.
*What is bridge ground wire? is that the cabel that come from the bridge OR the bridgepickup? cause i got a cable that is mountet underneath the bridgepick thats need to be soldered to a play.. its probibaly ground.
* on that diagram, you can see a black wire is soldered to 3 points on the Tone push/pull, but on the close up picture, i can i see that its only soldered 2 places. what is right?
* The diagram shows a different 3 way toggle than i got.
Im getting sound out of the guitar, but there is something wrong. So those questions i asked is what i possibly has done wrong since..   Im very happy if someone could help me out, cause im very close to get this rigth..  U can see on the picture here how my 3 way toggleswitch looks like. red on the left pin,white in middle on black to the right. but where should they be soldered?
Thanks!
