My totally subjective reviews
Started by metale, February 01, 2014, 09:14:04 PM
metale
It's been almost a week since I got my new BKPs on my Les Paul and Delonge ES and I'm ready to give my impressions on them.
I'm a bit reluctant to write this as it's really redundant: These pickups match what has been written about them here on the forums. I'll try anyway.
I already had the Black Dog on the LP bridge with a Mississippi Queen on the neck. They matched on mid-content, but the MQ felt more punchy, with more "snap". The BD felt/sounded a bit bright when changing from the MQ to it.
The MQ neck was now replaced with The Mule. Being a humbucker too, they somehow got along better instantly. I initially set the Mule at the same height as the MQ (low, almost flush with the ring), but to avoid a volume drop from the BD I had to raise it a few turns. Don't take what I will write next the wrong way.
They both sound related to each other, and each one of them does what I want from their respective position on the LP. But the Mule has a vintage tone (sweet, singing, vocal, touch sensitive are all words that come to mind) while the BD has a modern tone due to how it presents the mids (crunchy).
The neck BD would maybe be a better match to the bridge BD (duh), while the bridge Abraxas, Mule or Riff Raff would be a better match to the neck Mule. If I had two Les Pauls, I would have a BD set on one and a Mule+Abraxas set on the other. As it is with only one Les Paul, I'm not about to replace either pickup any time soon.
About the pickup height, I had to adjust the Mule a bit, and only on the last half turn did it really come alive. Suddenly, harmonics started jumping out and the pickup opened up.
________________________________________________________________
The Abraxas
There is no comparison between the Abraxas and the Dirty Fingers it replaced. They are nothing alike apart from being humbuckers.
Now that we got that out of the way  :) the Abraxas is installed on this single humbucker/single pot guitar with a push-pull coil split.
On humbucker mode, it's more compressed than the BD, and alot more compressed than the Mule, but in a fine way. The volume pot interacts this characteristic though, and the pickup cleans well. On split mode, the guitar suddenly sounds 3D. I can feel/hear the semi-hollow construction breathing, and the sound is neither thin or shrill, despite being on the bridge position. On my ES, the split mode alone is worth the money.
The Abraxas really suits the bright natural tone of the guitar (laminated maple body). Playing it, we don't feel we're limited by a single bridge pickup. Depending on where and how I pick I can set the attack without a tone pot, and with the two modes it's almost like having two guitars, two tones that totally complement each other. Yes, there is alot of hum in split mode with higher gain (obviously), but we can't hear it since the tone itself is so nice  8)
If the Abraxas is the Mule's uncle, the BD is a more distant cousin, but same family.
If the Abraxas is a BMW and the Mule a Mercedes, the BD is a Porsche. A RS3 Porsche.  8)
They all have that string separation and clarity, and they all clean up very well with the volume knob.
edit: "So, metale, how does the Abraxas does Brian May after all?" you ask?
With a treble booster, and even with only 2 modes, it does a better Brian May than the strat I just had modded to Brian May switching combinations. It's the right pickup for me, for the ES.
Great review, bravo!
You wanted more beef from the bridge, but still PAF-flavour. Hence I suggested the Abraxas instead of a Mule. Not a common choice for an ES, so good to know you're happy with it.
Did you fiddle with the height? I can make quite some difference with scatterwound pickups.
metale
I did not play with the height on the Abraxas (yet). I must have nearly nailed it when I set it the first time, because there is nothing I find missing from it.
And that split tone... I'm glad I went with you suggestion instead of Tim's this time :)
Will update this thread in the future as I try different settings, etc
Quote from: metale on February 02, 2014, 07:06:11 AM
That would be nice! Yeah, the splitted tones on the Abraxas and Crawler are imho more useable than VHII or Mule.
About the height: I noticed dramatic differences when I played with the height of the Crawler-bridge in my swampash strat. One mm to low and the chime was gone, and one mm to far up and it produced disharmonics. Got it right now.
Wayne_S
Yes pickup height is important. Seems the BKP's are bit more responsive in that regard, Ive just discovered that with the RY's. Thanks for the review Im itching for a Blackdog set and another LP  :D
1999 Les Paul Classic / Rebel Yell's
16 of 50 Dean Time Capsule Z / Duncan CS 78' & Alnico II
Charvel EVH Art Series / Stock pup
1984 Dean Baby ML / EMG 81 & 85
Splawn QR, SansAmp, Scholz Rockmans
Quote from: Wayne_S on February 02, 2014, 05:54:27 PM
The RY is known as one of the most difficult BKP's to set to the right height.
metale
Been playing with the ES (rectifier model on pod farm) and did a great Metallica playing along to the black album, both in tone and dynamics. Surprised me as the ES far from a mahogany explorer and the Abraxas is far from an EMG 81.
It's like they complement each other the opposite way: the ES's maple provides the tight dynamics, and the Abraxas provides the warmth.
