Author Topic: NAD - Peavey ValveKing MicroHead  (Read 5339 times)
Keven
« on: February 02, 2014, 02:16:08 PM »
going to the shop i give lessons at every weekend i stumbled upon this new arrival: http://www.peavey.com/products/index.cfm/item/805/118344/VK%26nbsp%3BMicro%26%238209%3Bhead
The peavey valveking micro head. it's a 20w dual EL84 all tube amp with built in attenuator (20w 5w or 1w) and internal dummy load for silent practice. and Usb Out, and Reverb, and Serial Effects loop, and footswitchable boost and channel switch and loop engage and reverb..
pheww! lots of features in this little box, and it's indeed tiny, 14.75 inches wide by about 7 inches tall.
The tone? well it's typical Peavey VK tone, some hate, some like. It works for what i wanted it as, a simple living room practice amp that doesn't need tons of pedals and cluttered cables to sound right. i plugged it into an Eminence lady luck 1x12 cab and i'm well on my way to glory.
being in canada i'm a bit screwed by the exchange rate but 500$ wasn't bad at all for the features you get. my only gripe is that you can't disable the speaker simulator in the direct out, would've been great to record using my redwirez IR's with just the usb out.
Reverb is great and a godsend when playing with headphones.
there's a bias pot inside so it's not fixed anymore like the old VK's.
the missus likes it too as it's got that simple streamlined look and also has the Loud but quiet tone that attenuation to 1w gives you.
here's a cr@ppy phone photo :)
« Last Edit: February 02, 2014, 04:36:10 PM by Keven »
My BK's:
C-Bomb Set / Blackhawk Bridge
Holydiver Set/ BG50 Set
Lew
Re: NAD - Peavey ValveKing MicroHead
« Reply #1 on: February 02, 2014, 04:16:16 PM »
Lovely job  8)
« Reply #2 on: February 02, 2014, 07:22:39 PM »
Nice :D
« Reply #3 on: February 02, 2014, 08:56:43 PM »
Congrats, sweet set!
littleredguitars2
« Reply #4 on: February 04, 2014, 05:14:43 PM »
i had the full size 100 watt valve king for 5+ years and i never had any problems. definitely solidified my trust in peavey. i always got compliments on my tone for my older youtube videos when i used it too. definitely a good high gain amp. maybe not in the same realm as the 5150 but it has a great sound
Lucifuge
« Reply #5 on: February 06, 2014, 08:57:14 PM »
Features look very similar to the H&K Tubemeister 18 but with the addition of the USB recording output.
