Author Topic: metale's red Squier strat - The Topic  (Read 7877 times)
metale
« on: February 08, 2014, 10:44:55 PM »
  • Intro
  • The Bad
  • The Good
  • Wiring Mod
  • Pickups
  • Aesthetics
Intro
Hi everyone. I decided to open this topic for Red, to kind of use as a journal. It's in the process of being modded, and will have a couple of BKPs. Could use you guys' feedback on them, and also on the aesthetics department.
I bought this guitar on late '06 / early '07, after seeing Frusciante with a red strat on the SA Tour. It's a '96 which my luthier was selling used.
Mid '90s Squiers were very inconsistent. I have two, and their body routing is different, pickguards have different quantity of screws, tuners are different, electronics were nothing alike, necks aren't interchangeable, etc etc etc. I like to mod them though, and tend to get attached to guitars independently of their price range or quality if I mess with them long enough.
The Bad:
  • It's not a pretty color
  • Stock pickups are the worst pickups I ever played
  • 'Modern C' necks aren't really my thing
  • Overall build quality is meh...
The Good:
  • Don't have to worry about keeping anything stock or vintage correct
  • The trem has the best return to pitch of any trem I've played, locking and non-locking
  • Natural sun-aged neck and plastics (it was displayed on the storefront for quite some time)
It was completely stock until now, apart from dunlop strap locks.
Looking inside:
Wiring mod:
As some have noticed, I'm a big Brian May fan, and wanted to get some BM combinations on this guitar. I toyed with the traditional 6-switch+2-pots idea for quite some time, but in addition of it being done now time and time again, I felt it toke away too much from the strat look.
So I planed the wiring to keep stock strat looks, with 9 switch combinations (7 BM settings and 2 stock strat settings). It now has a regular 3 way switch. Positions starting on neck side are:
  • Neck + middle in series (humbucker tone)
  • Neck + middle + bridge in series (more output, but muffled/muddy without a treble booster)
  • Middle + bridge in series (humbucker tone)
The first knob is a master volume.
The second pot is a push-pull (does nothing when rotated). When pulled out, the middle pickup is taken out of the circuit, so we have:
  • Neck only (stock strat tone)
  • Neck + bridge in series (sounds a bit telecaster-ish, but with more power)
  • Bridge only (stock strat tone)
The third pot is a master tone, and a push-pull which, when pulled out, inverts the phase of the neck pickup, so we have:
  • Neck and middle in series out of phase (think Bohemian Rhapsody Solo
  • Neck and bridge in series out of phase (haven't used this enough to form an sufficient opinion)
  • Neck + middle + bridge in series, with the neck out phase (funky, Rickenbacker-ish)
No parallel options. It's great to have all this versatility from a single guitar. The stock ceramic single coils though, they are plain bad. Dry, hard-sounding, lifeless. I must address that next.
Pickups:
Neck - I'm not swimming in money right now, so my plan is to use a Kent Armstrong designed alnico single coil I have laying around. It is the bridge model that was on the black squier before giving place to the SSL-5. Sounds good enough, and clocking at 6,38K DC resistance it's in neck Irish Tour territory, so I'm dropping in on the neck position.
Bridge - Probably will get an Irish Tour bridge with baseplate.
Middle - Undecided, but either another Irish Tour or a Slowhand. What do you guys think? The middle pickup is never on by itself.
Aesthetics:
Undecided on one of the following routes.
  • 3-ply mint green pickguard, cream plastics
  • Either metal or gold pickguard, with cream plastics but replacing the strat knobs with Gibson-style speed knobs (after seeing the new Fender Nile Rodgers strat)
Option 1:
Option 2 (imagine a red guitar :? ):
Cheers
Plenum n Heather
Re: metale's red Squier strat - The Topic
« Reply #1 on: February 09, 2014, 03:23:29 AM »
A brass scratch plate would look quite cool on that guitar ...
metale
« Reply #2 on: February 09, 2014, 06:58:48 AM »
Yes, and that's what is on the Nile Rodgers strat, but I only found this one.
As for gold, Fender has this.
They are both a bit expensive for this guitar, but I have dropped alot of money on cheap guitars before: my black Squier strat has cost me 70€ and has almost 250€ in mods  :?
« Reply #3 on: February 09, 2014, 10:29:59 AM »
I like the mint threeply scratchplate on red. If you fancy a bit of relicing you could take the gloss off en sand the back of the neck. Maybe it's going a little bit in the direction of Fiesta Red, which I like on a reliced guitar.
« Reply #4 on: February 09, 2014, 10:31:33 AM »
You've probably already considered/rejected the idea, but a gold anodised aluminium scratchplate would be cheaper than those brass ones, not to mention much lighter in weight.
Edit:  Rockinger sell a chrome plate too, similar price to Thomann (and I would guess it's the same part, made by ABM):
http://www.rockinger.com/index.php?cat=WG141&lang=eng&product=1500C&sid3=708b7f8395915688bbc2e418953a27b7
« Last Edit: February 09, 2014, 10:37:57 AM by Philly Q »
metale
« Reply #5 on: February 09, 2014, 11:26:04 AM »
The back of the neck still has aged color but feels bare wood. I sanded the back of the neck on both Squiers years ago using sandpaper by hand. It's very smooth.
Would be a possibility if it isn't more shiny/reflective than the brass ones. Weight is not a concern, this guitar is A LOT lighter than my teles :D
I'm also considering a full size steel trem block for sustain. Any feedback for the pickup choice, mainly the middle? I should record a sound sample with all the positions.
metale
« Reply #6 on: March 01, 2014, 06:59:10 PM »
I installed the original pickguard from my black squier, which is 11 screws instead of 8, 3ply instead of 1ply and a naturally aged cream instead of the pink-ish cream.
Only have a cr@ppy phone pic of the guitar with one of my loves:
I hate squier's 90s inconsistency. The screw nearest the jack is a dummy, as it now screws to a nice chunk of... oxygen.
