Author Topic: Intonation on Les Paul Standard  (Read 4434 times)
CommonCourtesy
  • King of da Chug
« on: February 18, 2014, 10:19:32 PM »
Trying to get the intonation right on my Epiphone Les Paul Standard. Top 3 strings are alright but whenever I flit between drop d and standard the A and D strings are always sharp/flat after I've turned the 6th string.
E.g If I was in drop d, and go back to standard, the A and D strings will be sharp.
Or if I go to drop d, the A and D strings go flat.
Why is this? Have I not been doing something right?
Help please!
« Last Edit: February 18, 2014, 10:45:20 PM by CommonCourtesy »
Re: Intonation on Les Paul Standard
« Reply #1 on: February 19, 2014, 11:01:00 AM »
'60s profile neck?  Sounds like your neck is twisting a little
CommonCourtesy
  • King of da Chug
« Reply #2 on: February 19, 2014, 12:46:56 PM »
I think so, 2012 model.
All started when trying to diagnose an irritating rattling sound when playing open A and D strings.
Might switch out the bridge for a Gibson model. Never been a fan of the Epiphone factory ones.
Alex
« Reply #3 on: February 19, 2014, 01:11:20 PM »
I'm guessing the neck is sensitive enough that the change in string pull from the low E makes a big enough difference. Some guitars can be very sensible like that. I had an SG where every little change made a difference, and a Voodoo LesPaul where almost nothing seems to impact a lot.
What gauge are you using?
CommonCourtesy
  • King of da Chug
« Reply #4 on: February 19, 2014, 01:25:05 PM »
Its not done this before until a few weeks ago. I don't think you can put Gibson hardware on an Epiphone either? Heard about tone-pro bridges though.
using EB Skinny top heavy bottom's, 10-52. This guitar acts as a back up in my band (we play in drop c) and also standard for teaching purposes.
« Reply #5 on: February 20, 2014, 01:15:20 PM »
My SG Junior and SG Standard both have the '60s profile neck and both twist as you tune up.  I tune from low to high and then check the low strings again. 5 and 6 usually need adjustment
The angle of the neck and nut on a Gibson can also cause problems with the G string.  This is very common.  It's more of an overnight thing though.
CommonCourtesy
  • King of da Chug
« Reply #6 on: February 20, 2014, 06:19:13 PM »
Yeah, I've sorted it out now, turns there were a few issues with the nut and bridge adjustment. I should know better not to tamper with it!
