Author Topic: 1meg vol +250k tone vs. two 500k pots?  (Read 8316 times)
silence2-38554
« on: February 19, 2014, 12:01:58 AM »
Can someone please explain the tonal difference between these two setups? I have the dual 500k setup in most of my guitars, had a 1meg volume in my 8 string for a while (with 500k tone), which made it a tad brighter, but adding a 250k tone would send more of that increased treble to ground. I'm just wondering what pairing a 250k tone with a 1meg vol. would offer compared to the typical 500/500 setup. I've heard a few people suggest it lately but without any real reasoning as to why...
Re: 1meg vol +250k tone vs. two 500k pots?
« Reply #1 on: February 19, 2014, 08:49:17 AM »
It is not quite as simple.
A tone control is wired as a variable resistor which controls how much resistance is between the tone cap and ground. A 500k pot gives you more resistance to ground than a 250k pot but if you turn down the 500k pot a nudge, you have your 250k pot. So if you want to most available tonal change on both ends of the control, stay with 500k. But if you want the most even spread of the tone control throughout its travel, go with 250k or 300k.
On the other hand, a volume control is wired as a voltage divider, not a variable resistance. A higher pot has more resistance to ground when turned up, therefore giving a lesser load to the pickup signal. If you turn down the pot, however, you will have more series resistance in line with the amp's input which could then dull the signal. This is way more apparent with an 1 Meg than say a 250k. I think 500k is a value that has proven to work well with humbuckers, providing an acceptable medium between a light load to the pickup signal and not too much series resistance when turned down. If you want to change to 1 Meg I recommend to use a "volume kit" which is a capacitor in parallel with a resistor which are soldered between the input and the wiper of the volume control. This helps to retain the highs when turning down the volume control.
Hope that helps,
Stephan
