Author Topic: Which Alnico V for the neck to match with a Crawler in a PRS CU22  (Read 2019 times)
Jasonbwebb1980
Just looking for a good match. Play a lot of Nineties Rock, most similarly Alice in Chains.
  • Random Solution
Re: Which Alnico V for the neck to match with a Crawler in a PRS CU22
« Reply #1 on: July 11, 2014, 07:57:47 AM »
The Crawler is an awesome pickup in the bridge of a PRS as I used one in a Custom 24 and I ended up using the guitar for almost everything. If you want an alnico V in the neck, I can heartily recommend a Holydiver. The light wind gives it a distinctly PAF feel to it but the AV magnet gives it more cut. It's nice and bright with a wonderful musicality to it. Takes loads of gain and has excellent cleans too.
The other option I used with some success was the Emerald neck. It's AIV but it's a hot neck pickup and uses a more modern wire than a traditional PAF so the feel and cut are a lot more modern.
« Reply #2 on: July 11, 2014, 08:25:39 AM »
VHII neck works well with the Crawler bridge.
« Reply #3 on: July 11, 2014, 10:17:40 AM »
If the Crawler-neck is too warm: VHII (like Stephan suggests), Emerald or Holy Diver.
