Author Topic: Ibanez Jem too bright  (Read 5351 times)
david_pri
  • BKPs: Holy Diver
« on: July 13, 2014, 07:53:41 PM »
Hi there, this is David from Spain.
I play in a metal band and I own an 2002 Ibanez Jem (Alder, Ebony, LoPro Edge, Evo set). The thing is, the sound is too bright to me, which is good to lead sound but I dont like my rhythm sound. Which BKP do you recommend to make my jem sound lower??
I am a big fan of Alnico Holy Diver. What do you think? Thanks
darrenw5094
Re: Ibanez Jem too bright
« Reply #1 on: July 14, 2014, 01:50:52 AM »
Holy Diver all the way. A common complaint about the Evo's, is brightness.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
« Reply #2 on: July 14, 2014, 09:09:54 AM »
The Holydiver sits well in bright guitars.
david_pri
  • BKPs: Holy Diver
« Reply #3 on: July 14, 2014, 01:12:46 PM »
Hey, thanks for the replies.
What about neck pickup? Any advice?
JimmyMoorby
« Reply #4 on: July 14, 2014, 01:58:37 PM »
Depends on what sort of sounds youre after but if your guitar is bright id suggest an aftermath neck.  Very warm but also very clear.  Perfect for metal leads.
Reminds me of Satriani around his crystal planet [eriod and Petrucci type tones.
« Reply #5 on: July 14, 2014, 04:15:07 PM »
Never played the Aftermath neck but output and spec wise it should be close to the Evo neck.
If you don't mind going lower in output for the neck, there are several options. I have used the VHII neck and still used the Cold Sweat neck with good results, especially in 24 fret guitars.
JimmyMoorby
« Reply #6 on: July 14, 2014, 04:37:14 PM »
I would have suggested the cold sweat but I didnt even like it in my 'balanced super strat' as I thought it was too bright and 'spanky'.  Nothing against the cold sweat absolutely fanatastic and even better than the aftermath but but id be weary of putting it in such a guitar that the OP has already said is bright.  I will say that is was very good in every way except for fast alternate picking a la petrucci, gilbert etc and as I say it took on a spanky clicky sound I really couldnt get on with.
Looking forward to getting it in my much warmer les paul though should work perfectly.......in theory.
« Last Edit: July 14, 2014, 04:41:54 PM by JimmyMoorby »
m t soule
  • VHII n,, HD b, NB b, CR n, ITm, Ab, Cs, Mm
    • Golem Painting Studio
« Reply #7 on: July 14, 2014, 05:18:31 PM »
Indeed to the HD, VHII combo. Thsts what I run in my RG550 with maple neck and board.
The attack on the vhii neck can get spanky if you get aggressive. Essentially giving you choice
I put some vids on this forum somewhere of clean to distorted, seek and discover x
T
RG550-Cr(n) S1(m) Ab(b)
RG550-VHII(n) IT(m) HD(b)
RG550-Cs(n) mm(b)
Jem-sfty3rds
Jem-Evo set
Jem-breeds
Frm250-air classic
had-Ry(b)  Nb(b)
« Reply #8 on: July 14, 2014, 06:43:48 PM »
One more vote for the HD/VHII- or CS-neck.
m t soule
« Reply #9 on: July 14, 2014, 07:31:43 PM »
RG550-Cs(n) mm(b)
Jem-sfty3rds
Jem-Evo set
Jem-breeds
Frm250-air classic
had-Ry(b)  Nb(b)
« Reply #10 on: July 15, 2014, 02:12:05 PM »
Agreed - the CS neck is brighter than the VHII neck. For a bigger tone VHII neck would be preferable.
  • Random Solution
« Reply #11 on: July 16, 2014, 10:24:05 AM »
To me, this screams out for the classic combination of Holydiver bridge and Emerald neck. Please keep in mind that the Emerald neck is NOT a bright pickup and the EQ chart on the website only refers to the bridge.
JimmyMoorby
« Reply #12 on: July 16, 2014, 01:02:09 PM »
I know im moaning again but I think BKP really do themselves a mischief by not describing the neck pickups more.
david_pri
  • BKPs: Holy Diver
« Reply #13 on: July 16, 2014, 02:25:57 PM »
Ok thanks everyone, I will consider VHII / Emerald / Cold Sweat. I love tight and big sounds, so does anyone know which one is warmer??
I like Petrucci leads, I am looking for a neck pickup in that way.
Thank you so much guys!!!
« Reply #14 on: July 16, 2014, 05:32:06 PM »
I already commented on the VHII vs. Cold Sweat necks. Never played the Emerald neck.
