Author Topic: Cold Sweat (neck) didn't hit the mark  (Read 9860 times)
Re: Cold Sweat (neck) didn't hit the mark
« Reply #15 on: August 16, 2014, 12:26:46 PM »
The Emerald neck is not bright. The EQ charts are bridge only.
The Emerald BRIDGE is bright.  There is a strong contrast between the two pickups.
Slartibartfast42 (author that review) used a Emerald neck with a Holy Diver in the end with great success.
With Full Distortion
  • With Fear I Kiss The Burning Darkness
    • Youtube
« Reply #16 on: August 16, 2014, 03:26:15 PM »
I Currently own that set, holydiver bridge, emerald neck and i just got a H-H 1 vol 3 way switch wiring diagram and ill be posting a review and/or video clip of the pickup as soon as i install and play with them a bit.
could you Case wait a bit ??
case report
  • Aquila non capit muscas
« Reply #17 on: August 16, 2014, 05:20:57 PM »
sure I can  :wink:
anyway, in this review I read something that leads me to the Crawler...  :rolleyes:
https://bareknucklepickups.co.uk/forum/index.php?topic=30278.0
Gibson Les Paul Historic 1958 - Stormy Monday
Charvel San Dimas - Holydiver (b) -Crawler (n)
Jackson Fusion Pro - Holydiver & Trilogy Suites
m t soule
  • VHII n,, HD b, NB b, CR n, ITm, Ab, Cs, Mm
    • Golem Painting Studio
« Reply #18 on: August 16, 2014, 09:47:59 PM »
I have to reiterate that you check what pots n caps you have. No pick up will hit it's potential otherwise.
RG550-Cr(n) S1(m) Ab(b)
RG550-VHII(n) IT(m) HD(b)
RG550-Cs(n) mm(b)
Jem-sfty3rds
Jem-Evo set
Jem-breeds
Frm250-air classic
had-Ry(b)  Nb(b)
case report
« Reply #19 on: August 16, 2014, 10:12:27 PM »
m t soule , I will check the wiring...
Yes I do, don't worry  :police:
I only need time because I can't measure now... but in the meantime I try to get more infos  :wink:
EDIT: I see no cap inside and the pot is a CTS where is written 037407  1112
« Last Edit: August 16, 2014, 10:20:07 PM by case report »
darrenw5094
« Reply #20 on: August 17, 2014, 12:40:54 AM »
Abraxas is a darker pup set, could be just what you want, like a PAF with more mids. Crawler also is more dark sounding, probably fatter than the Abraxas.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
    • Youtube
« Reply #21 on: August 17, 2014, 04:40:19 AM »
mine has a generic 500 k pot only for volume. no caps.
« Reply #22 on: August 17, 2014, 04:59:47 AM »
The problem usually arises on Gibsons, which often come with 300K volume pots
case report
« Reply #23 on: August 17, 2014, 10:36:18 AM »
In fact I'm looking for a fat PAFish sound, darker than CS
For exemple, I have Holydiver also in a Jackson and because of woods it sounds darker than Holydiver on Charvel; I mean Charvel tend to be a bright guitar. Otherwise in my amp it's easier correcting dark sound than bright, so I think it's not a risk choosing a dark pick up like Crawler (or Emerald or Abraxas)
« Reply #24 on: August 17, 2014, 11:39:04 AM »
Crawler: after Telerocker advice I checked specification and samples on the web and it seems to me very interesting for my purpose. On BKP site is written "Although Geoff wanted contemporary power from the bridge, the Crawler neck humbucker is voiced like a vintage PAF, open and vowel-like, with a calibrated wind to balance in output."  :grin:
What about Abraxas neck?
The Abraxas neck is very similar to the Crawler neck, but just a little brighter.  Based on what you've said so far I'd lean towards the Crawler.
The Mule, Abraxas and Crawler neck models are all from the same "family", Alnico IV magnet and DC resistance of 7 point something.  The Emerald neck also has the AIV magnet but with different wire so the DC resistance is higher, although I doubt it's actually much "hotter" than the other three.  I believe Slartibartfast42 compared the Crawler and Emerald neck models in one of his reviews already mentioned.
m t soule
« Reply #25 on: August 17, 2014, 11:52:16 AM »
Here is the Crawler in neck position. In basswood. Tuned to Eb.
For me the crawler is pretty bassy and can pierce if attacked aggressive
Distortion
http://m.youtube.com/watch?v=S7sDbF1OPEM
Overdrive
http://m.youtube.com/watch?v=LqudCEimgoo
Clean
http://m.youtube.com/watch?v=l9YALD14bXQ
« Last Edit: August 17, 2014, 12:14:34 PM by m t soule »
RG550-Cs(n) mm(b)
Jem-sfty3rds
Jem-Evo set
Jem-breeds
Frm250-air classic
had-Ry(b)  Nb(b)
m t soule
« Reply #26 on: August 17, 2014, 12:12:44 PM »
And for comparisons sake heres the vhii neck.
For me this is the ideal pup I have used so far in the neck. P
Clean
http://m.youtube.com/watch?v=VTGpBNX5iu4
Distortion
 http://m.youtube.com/watch?v=AhOl9MHbwjc
RG550-Cs(n) mm(b)
Jem-sfty3rds
Jem-Evo set
Jem-breeds
Frm250-air classic
had-Ry(b)  Nb(b)
case report
« Reply #27 on: August 18, 2014, 02:16:49 PM »
Thank you m t soule  :wink:
