Author Topic: Fender CS relic HSS pots and pickups  (Read 3151 times)
dd6094
« on: August 20, 2014, 07:33:02 PM »
Hi, I have a HSS custom shop heavy relic and want to BKP it.
Problem....
It's a custom build that I picked up second hand and it has an S1 switch (which I like as it allows me too switch the humbucker in and out).
I always use nailbomb bridges with 550k pots, however as the knobs are aged and rare as hens teeth and the S1 knob won't fit a standard pot would a Rebel Yell compensate for the top that I would lose with a nailbomb running through a 250k pot?
As I may have to retain the fender 250 pots just wondering if a brighter pickup like the RY might prove a suitable compromise.
It has a Duncan 59 in there at the moment, bright despite the pot but not enough clarity or umph for how I play.
Rock / alternative, Splawn Quickrod or CAA OD 50 se+ Through vintage 30 loaded 2x12's
Cheers
James
« Last Edit: August 20, 2014, 08:29:07 PM by dd6094 »
Nailbomb set, Coldsweat set, Miracleman bridge, black dog bridge, Crawler bridge, Mule set, Holydiver bridge, Rebel yell set, Stormy Monday set, Sinner, Trilogy mid/neck, Boss set
Re: Fender CS relic HSS pots and pickups
« Reply #1 on: August 21, 2014, 09:17:26 AM »
You have a dilemma. Pickups with 14k DC resistance of 43ga wire like the RY bridge usually sound best with 500k pots. If your guitar is bright, a 250k pot may work. Unfortunately there is no way to know for sure until you have it in your guitar.
The amp does not really call for a super high output pickup. You may consider the VHII bridge (even if this is not one of my favorite BKPs) or the Black Dog bridge.
dd6094
« Reply #2 on: August 21, 2014, 06:07:26 PM »
Thanks for the reply, I do use high gain amps and have tried black dogs and other lower output pickups before but I like the umph that higher gain pickups give.
I preferred the nailbomb to a RY in both a Les Paul and a Luxxtone, too much top end, which is why I thought it might just work with a 250 pot.
Anyone out there using 250k?
« Reply #3 on: August 21, 2014, 10:10:03 PM »
Look at the Holy Diver, it suits strats well and fits your wishes I think. A tad more vintage but with serious balls and with a great split, is the Crawler. It sounds stellar in my strat and does hardrock and oldschool metal very well.
dd6094
« Reply #4 on: August 22, 2014, 08:56:32 PM »
Hi, thanks for the suggestions, I've tried both a Holydiver and a crawler with 250 pots, the HD was way too dark though I imagine it would be excellent with 550 pots, and the crawler was also a little too dark. I'm thinking the Rebell Yell will be the only pickup with enough push and trebble to work.
James
« Reply #5 on: August 22, 2014, 11:51:00 PM »
James
250K is for single coils. Humbuckers sound best with 500 or 550k. I have 500k pots in my HSS-strat and the singlecoils (Irish Tours) sound fine. No icepick or whatsoever.
