Author Topic: Epi Les Paul studio Full Upgrade  (Read 3377 times)
gillham
« on: August 21, 2014, 02:25:19 AM »
HI fellers, new guy here after a few opinions!
I'm in the process of fully upgrading my 1998 les paul studio and I'm after your opinions on some bare knuckle combinations...
I want something quite bitey and crisp in the bridge and something nice and warm in the neck. I play in a few different styles rock indie vintage rock etc so I don't want to be tied down with a pair of humbuckers that aren't as versatile as I need.
Any opinions are greatly appreciated,  cheers guys!
Scott.
Re: Epi Les Paul studio Full Upgrade
« Reply #1 on: August 21, 2014, 03:11:54 AM »
A Cold Sweat set should get you there, given what you've said about 'bitey and crisp in the bridge'.
Yellowjacket
« Reply #2 on: August 21, 2014, 04:56:46 AM »
A-Bomb bridge and Rebel Yell neck.  It makes for one hell of a versatile LP.  (That's what I have)
DagleBee
« Reply #3 on: August 21, 2014, 08:50:51 PM »
There was a member who proudly said that with the right gear a Riff Raff will do almost anything . And I tend to agree with that :) I don't personally own that pickup but did a lot of research . It's a low output if that interests you but has some bite and that let's call it vintage stingy top end . It should fit in the studio just fine and it's versatile :)
 It;s the closest to a burstbucker from Gibson . But a lot of folks assured me it's better ! I stumbled across a very interesting video about the burstbuckers and Lp style guitar . Take a listen . and yes , that tone is achievable with BK pickups :)
https://www.youtube.com/watch?v=-duj8uNLdjs
The Riff Raff bridge will work well either with the Riff Raff neck ( which is said to have a nice single-coilish vibe ) or the Mule ....The RR bridge and mule neck is a combination used by the man behind BKP . I almost went for this combo for classic rock , rock-blues and hard .....I don't know what change my mind but I will sure try the RR mule combo .
An emerald will be a step forward is you think the RR is not hot enough. Ask if you need more info on this one....i won't write you a novel :)
Hope that helps :)
« Last Edit: August 21, 2014, 08:57:47 PM by DagleBee »
« Reply #4 on: August 21, 2014, 10:05:49 PM »
Mules-set!
BigB
  • Let's rock !
« Reply #5 on: August 21, 2014, 10:16:17 PM »
You just described the Mules. So you want Mules. Definitly.
gillham
« Reply #6 on: August 22, 2014, 07:42:13 AM »
Thanks guys. I'll be getting these ordered....
...After I've taken Mrs on holiday.... haha
« Reply #7 on: August 22, 2014, 11:58:34 PM »
Play with the height as scatterwound are sensitive for that.
Yellowjacket
« Reply #8 on: August 24, 2014, 04:21:43 PM »
Be sure to upgrade your pots and caps as well.
