Author Topic: Painkiller bridge better for CE22 or Ibanez RG3120?  (Read 2204 times)
Exodus5
« on: August 29, 2014, 02:05:48 PM »
I have two mahogany guitars with maple tops and similar maple/rosewood neck/fretboard combos.  Would the Painkiller sound good in either of these guitars?  I had it in a LP and it sounded fine, but since both of these are thinner bodies I wonder if it will still work well?
Exodus5
Re: Painkiller bridge better for CE22 or Ibanez RG3120?
« Reply #1 on: September 03, 2014, 01:55:13 PM »
Sold the Ibanez, so I guess the CE is the lucky recipient of the PK.  So is the Cold Sweat the go to neck pickup to pair with the PK bridge?  I see them paired up a lot.
darrenw5094
« Reply #2 on: September 03, 2014, 09:15:03 PM »
I am sure that PK will work fine in the CE.
My Pk is paired with a riff raff neck, so I would say the CS will work ok
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
MerlinTKD
« Reply #3 on: September 04, 2014, 04:54:27 PM »
The official demos on the pickup pages are (IIRC) all done with a Les Paul, so the PK should sound very similar in your guitar (depending on your rig, of course).
Zimbloth has said the PK sounds best in mahogany, better there than any other wood; I have a set in a basswood 7, and I can see how the high mids of the PK would balance awesomely with the low mids of mahogany! Probably better in the PRS than in the Ibanez, since the PRS is a slightly shorter scale, taking a little edge off, so you sold the right guitar!  :wink:
Re: neck pickups, it depends on the sound you want. I love the PK neck, in my basswood it's fluid, but edgy, super clear; it like a lot of bass from my amp (model) but never ever gets muddy; with a boost and a little flange/delay/reverb, I can make it sound like an 80's analog synth!  :laugh: But the CS neck is the go-to classic shred pickup, and is often paired with the PK; to my ears (I don't have one personally) it's sweeter and less edgy than the PK, but still cuts through just fine.
You can't go wrong, I think!  :grin:
LTD M-207: Painkiller bridge, Painkiller neck
