Author Topic: Need help figuring out correct wiring!  (Read 6986 times)
olrac
« on: October 05, 2014, 10:50:26 PM »
Wiring is always my downfall on new builds. Here what I am looking for;
P90 neck (single cond. and braid) volume and tone
Abraxas Bridge (4 cond.)volume and Push-Pull tone for split coil
3-way select switch
Having a hard time finding a wiring diagram, any help will greatly appreciated!
This is the build I am finishing.
« Last Edit: October 05, 2014, 11:05:10 PM by olrac »
Toe-Knee
    • DIY Audio
Re: Need help figuring out correct wiring!
« Reply #1 on: October 06, 2014, 07:50:23 AM »
This one should do for you.
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h2v2t3w2sp
Just ignore the neck switching part and convert the wire colours to BKP.
Also that is a very nice guitar. It's a shame you built it backwards.
Oh yeah also ignore the additional wires on the neck pickup as you will only have hot & ground on the p90.
« Last Edit: October 06, 2014, 07:52:59 AM by Toe-Knee »
http://WWW.BACKLINE.TK
Non Biased Guitar Forum
http://fret.boards.net
« Reply #2 on: October 07, 2014, 10:06:01 AM »
Bridge humbucker and neck P90 is a great combination. We want to see more of these.
Beautiful guitar BTW.
olrac
« Reply #3 on: October 08, 2014, 10:31:30 PM »
Thanks Gentlemen!
The neck P90 is from a 1954-56 Goldtop. I got two of them back in 1978-79 when this kid came into my friends music store and asked him to convert it to two humbuckers. He sold them to me for $30 dollars to use towards some DiMarzios he wanted to put in to it. I gave one to another friend about year after that for a tele conversion and kept this one just because.  It meters out at 8.1 . I had it in a tele conversion as well cause it sounded  so good. At the end of a gig many years ago a van ran over it before it was loaded up and trashed the guitar, but not the pickup. It has sat in my old parts bin for about 25 years so I figure it's about time to put it back into service. (You accumulate a lot of Sh*t over 47 years of playing). But I still suck at wiring, my arch foe!
« Last Edit: October 09, 2014, 12:50:40 AM by olrac »
« Reply #4 on: October 09, 2014, 11:40:07 AM »
Very nice
Do you intend to use left handed taper pots or are you used to having everything right handed?
You may have to jump through a few mental hoops to orientate that diagram to a lefty orientation.
(can you get long shaft left handed taper CTS ? or have you cleverly routed to allow standard length pots?)
olrac
« Reply #5 on: October 17, 2014, 06:10:26 AM »
Went with a S.D. Triple Shot PU ring for the split.  My Pots should be in this weekend to finish up this build.
