This is not normal!!
Started by CommonCourtesy, October 16, 2014, 10:37:56 PM
CommonCourtesy
So I had a rehearsal tonight, and my low 6th string broke, near the bridge, as it usually did before, it was always one of the lowest 3 strings. I play in drop c tuning, and use Ernie Ball 12-56's.
It happened earlier in the year and I had the saddles cleaned and filed so they were all smooth. Thought I solved the problem there. But tonight it broke again, and I had only restrung it 2 weeks ago. Have checked and there's no burrs, haven't done much gigging for me to sweat into the grooves (which was probably causing the previous breakages) and I've strung it up ok.
So what else could it be? Cos for a new string to break within 2 weeks is something I don't get. I use a 0.88mm pick and am quite heavy handed, but usually its taken it ok.
I use a 1.14mm pick, doubt it's the pick ... could be your picking action, but again I doubt it
I does seem like you might be a bit rough with them somehow, but have you considered the Graph Tech string saver saddles?  I haven't broken a string on my SG Junior since installing a bridge incorporating those saddles, whereas I broke two strings on the Gibson wraptail that was on it originally and have broken at least one string this year on my Explorer with the TonesPros bridge
Obviously they also sell complete bridges but for Gibsons etc you can get replacement saddles.
http://www.graphtech.com/products/brands/string-saver
They will change your sound slightly - whether that's good or bad is up to you.  You lose a bit of the 2K harmonics but gain them across the rest of the range.
Toe-Knee
It could be bad strings. I had this problem constantly on guitars with TOMs when using D'addario or Ernie Ball.
On guitars with trems or Gibralter bridges which have strattish saddles I have never broken a string.
When I was using a les paul and currently on my Jackson I use DR Tite Fits or Elixirs and have never had one break.
I never did quite figure it out but the local store said its a common issue to do with the sharp break angle over the saddles how much truth there is in that I don't know but he was the one who recommended changing to DR & elixirs as they don't break as often.
[url="http://www.backline.tk"]http://www.backline.tk[/url]
Non Biased Guitar Forum
[url="http://fret.boards.net"]http://fret.boards.net[/url]
CommonCourtesy
I'm trying to resist graphite as I have read they do affect your tone, lack of sustain, etc.
What other string brands do 12-56? I know DD do 11-56 or 12-60. Or do coated strings make much of a difference?
If its the quality of the string, I surely can get more than a fortnight's use out of the string at least? This is really pissing me off and if this is something that happens live then we have a problem!
If you have a 10-band EQ like mine you can compensate for the graph tech saddles by boosting the 2K
Personally I found that works, but I also found that with the 2K a bit lower the lead guitarist is easier to hear over me.
Toe-Knee
Quote from: CommonCourtesy on October 17, 2014, 02:08:41 PM
It's not neccesary quality I have just never had luck with TOM bridges and EB or Daddario they always break near the saddle and the tech backed me up on it. However there are probably millions of people who do use them without issues also.
CommonCourtesy
Hmm, all I've ever used are DD and EB, never tried anything else. Can't seem to find any other brand that do 12-56 either, tends to be 11-54 or 12-60! Would mean filing the nut I think, for the 60 anyway.
The only thing that puts me off graphite saddles is the change in tone, like will it be noticeable? I could always try picking less hard but live its hard, or I could use a 0.73mm pick, not that it'd make much of a difference.
You actually gain some harmonics across the board but you lose that 2K spike.  You can compensate with an EQ.
The other thing you might consider is top-wrapping your strings.  If the issue is the break angle that will help, whereas a graphite saddle might not in that instance.
How are your strings breaking?  Does the core break first and then the string goes loose and floppy, with the winding still intact? The first time that happened someone said it might have been sweat related, and it did it again a couple of weeks later.  Of course the geometry etc would have had some impact, but it is also the area where I rest my hand when palm-muting. I imagine you do a lot of that.  If you are getting very sweaty maybe try a wristband
I haven't had a string break on that guitar since I installed the string saver bridge but that has also been the period since last summer.  We'll see how I go through this summer
CommonCourtesy
What exactly does a "2K spike" mean?
I know you can get the classic string saver saddles which retain the original look of the stock one, but its not looks I'm fussed about its the sound.
The string breaks on the saddle at the ball end obviously, so yes it goes floppy and winding is still intact. I had an photo of an old string break showing exactly where it was, which I'll try to find. The sweating thing is a major factor I think, esp live, but it broke during the chorus of a song which was 3 powerchords! Just annoyed me it was a string that was barely a fortnight old.
The bit of my hand that sweats the most isn't my wrist its the fleshy part my my hand, parallel to where the 4th finger is. That sits on the string saddle area the most.
Quote from: CommonCourtesy on October 18, 2014, 01:50:04 PM
I don't suffer from sweaty hands so I guess I was assuming it was running down your arm, which is what I experience and where the sweatbands could help.
By a 'spike' I mean that there is a clear harmonic around 2K that gives the metal saddles that 'bite' that might be missing with the string saver saddles. I boost that frequency a little with my 10-band EQ.  I didn't notice any worsening of tone, but then again I went from the 'lightning bar' wraptail to a bridge with actual saddles on it, so it's hard to compare.  I have a properly intonated G string now, which I prefer over the stock wraptail even if the tone changed somehow.  I'll take tune over tone any day!  Your case is a bit different, in that it would just be changing one saddle material for another.  I guess it's a 'suck it and see' kind of thing.
CommonCourtesy
Hmm maybe sometimes I'm too busy going crazy and running around to notice! I try to wipe down the strings after every time I play, including the saddle area. During rehearsals (which is when the breaks are occurring) I'm usually wearing a long sleeved top so I don't get sweaty running down my arms.
Ok well, I guess I won't really know what the difference will be til I try one with a different saddle. I have a pretty dark sound anyway, if its too bright it won't sit in the rhythm section very well.
#11
The danger is not in getting more bright, if you are losing some at 2K then it would be getting darker.
Also, have you tried top-wrapping the strings over the tailpiece?  That reduces the angle.
http://jalan.hubpages.com/hub/The-Wrap-Over-Method-How-To-Avoid-Breaking-Electric-Guitar-Strings
CommonCourtesy
Its a mahogany wood guitar, to me it doesn't sound bright, some people say it is.
I haven't, no as it reduces sustain apparently.
I found that top wrapping increased sustain, for one reason only: I can drop my tailpiece flat to the top when I do it.
Toe-Knee
It sounds to me like its sweat corrosion that is causing your problems. I'd give coated strings a try.
