Author Topic: Vintage hot bridge humbuckers  (Read 5335 times)
Alex
« on: October 25, 2014, 07:00:41 PM »
I currently have three guitars that all have contemporary pickups in the bridge. I am looking or something "more vintage" and a previous thread (long time ago) gave me some ideas.
I'm kind of stuck between the VHII, the Riff Raff and the Black Dog. The guitar is an ESP Eclipse and this particular one is a relatively dark sounding guitar with lots of mids. It once had a Seymour Duncan JB in it and that was not tight enough, too dark and too mushy on the low end.
Currently it has a Miracle Man in the bridge and a VHII in the neck. Here's where the trouble starts:
I want to keep the VHII in the neck. It does feel to me though as if it is very loud (when I play it clean) and my spec card lists it at a DC resistance of 8.3K, which sees a bit odd that it's .4 over the usual spec.
My questions: Would a VHII bridge be too mushy on the low end? Would a Black Dog bridge be too dark on the top end? Would a RiffRaff be overpowered by the VHII in the neck?
Soundwise I'd like it to be versatile really, but generally deep and clear with lots of "wood" coming through in the sound.
darkandrew
Re: Vintage hot bridge humbuckers
« Reply #1 on: October 25, 2014, 11:07:43 PM »
Hi,  I'm probably going to be trying my VH II bridge in one of my Eclipses later this week (I want to try the RY that I currently have in it in another guitar which in turn has a VH II set in it). I'll let you know how it turns out.
Alex
« Reply #2 on: October 26, 2014, 09:14:48 AM »
Thanks, that would be great. You can send me a PM if you prefer.
littleredguitars2
« Reply #3 on: October 26, 2014, 02:58:39 PM »
frankly i didnt like the VHII in my les paul custom. its not tight at all and the low end didnt do much for me. i feel like they are better suited for a super strat. i feel like the riff raff or mule would both be really good choices. if you're concerned about output maybe the abraxus
« Reply #4 on: October 26, 2014, 04:11:06 PM »
Mule or a RiffRaff, if you want a woody tone.
Alex
« Reply #5 on: October 26, 2014, 08:00:13 PM »
Hm, that doesn't bode well for the VHII bridge then.
Would a bridge Riff Raff be able to keep up with the VHII neck volume-wise?
« Reply #6 on: October 26, 2014, 08:52:23 PM »
I don't think there will be a balanceproblem. You can always adjust the balance with height and, if necessary, different pots.
« Reply #7 on: October 26, 2014, 09:00:45 PM »
Considered the Emerald?
Alex
« Reply #8 on: October 26, 2014, 10:43:26 PM »
No, I want to stay under the 10k resistance really. The Rebel Yell would have been the other choice otherwise.
« Reply #9 on: October 26, 2014, 11:06:18 PM »
the VH is quite bassy heavy, but very percussive and non-mushy
it's a like riff raff x cold sweat mix
I don't think the black should sound dark, but it does have a rounder top than the others
the neck vhII has close specs to bridge riff raff and does sound pretty close to a riff raff when installed in bridge position
the main difference is the slight midscoop vs the riff raff full midrange (not bumpy like the dog, but full)
considering the extra mids of the riff raff, I think they can balance well with proper height adjustments
I like the bridge riff raff very close to strings and the neck vhII set very low
« Reply #10 on: October 27, 2014, 02:20:51 PM »
No. It's a very tight pickup.
No. It's a rather bright pickup, much brighter e.g. than a Holydiver or Alnico Nailbomb.
Most likely yes.
I have not played the Riff Raff bridge but for the tone you want I would recommend the Black Dog over the VHII.
darrenw5094
« Reply #11 on: October 28, 2014, 01:39:03 PM »
Think the RR is better balanced than the others. Mule is vintage, but can handle the gain very well without getting mushy. but is a tad bright.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
« Reply #12 on: October 28, 2014, 06:31:39 PM »
The Black Dog is less woody than the RR and the Mule. Just to know.
darrenw5094
« Reply #13 on: October 29, 2014, 12:47:40 AM »
Hmmm.....the Black Dog, my least fav BKP because of the heavey low mids and vacant high mids, puts the balance in a strange way for me.  :tongue:
Mule - Les Paul
VHII - PRS CU22
Emerald - Les Paul
darkandrew
« Reply #14 on: October 29, 2014, 09:01:25 AM »
I've not had a chance to swap my VH II and RY around yet, and to be honest I think the RY is going to be too strong in the upper mids for that guitar,  but back to the topic of the VH II in an Eclipse; the thing about the Eclipse is its lack of resonance. They're great guitars to play (I have three of them) but even though they have a set neck construction with a mahogany / maple body and mahogany neck they are very dry, when compared to a Les Paul for example, which presents some problems when choosing pickups for them. My experience is that unless you are a very technical and disciplined player (which I'm not - I started out as a bass player!) then a slightly compressed pickup is going to be high on your list of desirable characteristics (the guitar's lack of resonance doesn't smooth out differences in playing dynamics in the way that a much more resonant guitar would). I've tried a few different pickups in my Eclipses and my favourites so far are Rebel Yells, Crawler (bridge) and an EMG 57/66 set. The most disappointing was the Alnico Nailbomb set (mainly because the bridge was so sensitive to dynamics which was really emphasised in the Eclipse) but they sound awesome in my Telecaster HH (again, mahogany set-neck with a mahogany/maple body but much, much more resonant). Personally I'm tempted to try a set of Cold Sweats next.
I hope I haven't rambled on too much and that some of that is useful to you.
« Last Edit: November 01, 2014, 12:27:56 AM by darkandrew »
