Author Topic: Rebell Yell a bit short on body: thicker pickup for Mahog/Rosewood bolt-on?  (Read 2062 times)
Pierre
GAS is striking again :)
The Albert Lee HH (Mahogany body, full Rosewood neck, hardtail) sounds amazing with the RY in the bridge, but I'm thinking I could use a little more growl. Output is fine: maybe just a bit lower mids/bass.
Alternatively, a pickup with more muscle AND output will be fine too ;)
I was close to going for a Crawler but man that pickup sounds HUGE, and it may lack a little treble for the AL, a rather smooth sounding guitar (where a Strat is on the snappier end of the spectrum).
Nailbomb is too modern/powerful sounding... and that's about where my BK knowledge for humbucker stops these days!
Any ideas? Thanks!
JimmyMoorby
Matches the descriptoon of the alnico nailbomb but you say thats too powerful so I have no idea?!
m t soule
  • VHII n,, HD b, NB b, CR n, ITm, Ab, Cs, Mm
    • Golem Painting Studio
I felt the same about the ry bridge and swapped for a hd instead.
Yes the voice maybe slightly different but it does hit the spot for me.
Would I still like a touch more bass still? Yes.
Having never tried an a bomb I am not in a position to give an opinion. I hear it's essentially the ry bigger brother.
I have a cbomb and can say to me they are a world apart.
I did some comparison vids in my signature below earlier vids use a model amp, later vids use a tube amp so take that in consideration.
(bypass opinions on my sjit playing tho)
T
« Last Edit: November 04, 2014, 05:42:02 PM by m t soule »
RG550-Cr(n) S1(m) Ab(b)
RG550-VHII(n) IT(m) HD(b)
RG550-Cs(n) mm(b)
Jem-sfty3rds
Jem-Evo set
Jem-breeds
Frm250-air classic
had-Ry(b)  Nb(b)
I assume you have, but just to make sure: Have you played around with the height of the pickup? With all BKPs, but especially the RY that makes a huge difference, especially in the low end.
Yellowjacket
A-Bomb for sure.  Such a fun pickup!
Now, you could try a heavier weight of strings or mess with the height of the pickup but the A-Bomb will give the extra bit of weight in the lows / low mids along with a really raw and pissed off tone.  It has slightly more output and more hair / thickness to the tone.  It has a really lively treble with lots of pick dynamics, just like the Rebel Yell.  The Rebel Yell has more harmonices, but the A Bomb has more treble and cut, as well as a a phatter tone with more hair.  It's super fun to play!!
