why is my low e string in drop b can be in tune properly?
Started by aidilomorello, January 08, 2015, 05:22:59 PM
aidilomorello
My band started playing  drop b and i set up my guitar myself but one problem i found is that my low b string won't stay in tune, it simply wont go to green on my tune it keep goin either sharp or flat
aidilomorello
and also all my other strings is perfectly in tune on my tuner except for that low b strings.
my guitar is 25.5 inch scale and has floyd rose
Did you make sure your other strings are muted?  The low frequency might be causing one to vibrate and interfere with your tuner
oncesolemn
What guage is your lowest string?
-I don't like to use anything below a 56 for B on that scale length
What tuner are you using?
-Some don't like extended range tuning!
aidilomorello
Quote from: Agent Orange on January 09, 2015, 02:59:01 AM
i did try muting the strings i does help abit but not much
aidilomorello
Quote from: oncesolemn on January 09, 2015, 01:38:46 PM
My Low B string is a .60 gauge string and im using a mooer baby tuner (Chromatic pedalboard tuner)
oncesolemn
What's the Guitar Tech situation where you live?
Anybody you know with a good rep maybe could help you?
aidilomorello
Quote from: oncesolemn on January 10, 2015, 12:25:27 PM
i think i know someone.
but i started to think it might be the machine heads maybe just because th strings are too thick.
oncesolemn
Could be..what are the heads on this guitar?
Do you have access to another tuner you could check with?
Alex
Or try a thinner string just to check if it is the very thick gauge that is creating the problem.
Mkjackary
Some tuners find it hard to track at low frequencies, similar to tracking of digital pitch effects.
Also without a locking nut the note produced when you hit the string will "bounce" going from higher to lower then rest at the normal. As the initial note you hit will change so much the only fixes/things that help are using a locking nut, Use thicker strings (or anything that will give you higher tension).
Try not hitting the string so hard when you tune the note, this will reduce the amount it goes out of tune when the string is initially hit :)
