Author Topic: Juggernauts + Kemper Profiler + Ibanez RG8 Basswood  (Read 7039 times)
Chargrilled
« on: February 13, 2015, 03:37:43 PM »
Cleans + Solo are Juggs Neck, distorted power chords are Bridge. Guitar is a Basswood Ibanez RG8. This is actually an 8-string but not used the low fat string for this one.
https://soundcloud.com/imran5000/tuva/s-zHh5L
« Last Edit: March 23, 2015, 08:33:47 PM by Chargrilled »
darrenw5094
Re: Juggernauts + Kemper Profiler
« Reply #1 on: February 16, 2015, 01:52:03 PM »
This link working?
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
JacksonRR
« Reply #2 on: February 24, 2015, 08:27:14 PM »
The link does not work and your profile says that you have not shared any public sounds. Perhaps a check of settings is in order?
Chargrilled
« Reply #3 on: February 25, 2015, 06:03:42 PM »
Here we go - I reset the link for some reason!
JacksonRR
« Reply #4 on: February 26, 2015, 04:08:31 AM »
Good stuff! Solid midrange there. :)
Chargrilled
« Reply #5 on: February 26, 2015, 01:03:33 PM »
Cheers! I didn't mess with the EQ on the Kemper at all, only rolled off at 100 kHz and 7000 in my DAW - I think I might have removed a bit of the punch of the distorted guitars though may re-EQ at 80-90khz roll off
JacksonRR
« Reply #6 on: February 28, 2015, 05:35:38 AM »
Whenever I feel there's a lack of punch, I turn down the gain and just ram that pick into the same territory that I had before. I've never dealt with a Kemper, but I do use Overloud's TH2 when the timing calls for it, more often than not recently. I usually do put an analog preamp signal in and simply use it for the lower volume and the cab simulation(the George Lynch cab is really good, actually). If I had any critique, or it was my mix, I'd reduce the overall guitars by 1.5-2db and boost a hair in the 1.3Khz range, but.... tastes vary and I did appreciate how solid your tone was as it was shared in the original clip. It's always a struggle when mixing to not fiddle some more.. and a little more.... and then a little more... That being said, I'm also adjusting to new monitors on a new desk in a new room, so take it all with a grain of salt and best wishes.
oceansandatlantic
  • BKPs:piledriver bridge.flat 50se.juggernaut bridge
« Reply #7 on: March 11, 2015, 08:27:58 AM »
This is amazing. I just order a bridge juggernaut and was skeptical about it until this clip. I only hope the bridge clean gets pretty close to the neck cleans.
Chargrilled
« Reply #8 on: March 11, 2015, 11:32:34 AM »
Thanks! For your info the amps used on the Kemper are Rectifier L + R, Diezel down the middle. I actually should have recorded the bridge clean however they sound superb as well
