Wiring Pic.... Help needed
Started by Bird, March 24, 2006, 10:12:04 PM
Bird
This is how I got the guitar back from the shop. The humbuckers are working but the Trilogy isn't for the most part. The 3 middle positions on the 5 way are barely audible.
sambo
woah... looks a mess to me... lol... i only say that cause although machinehead are bloody useless the wires were extremely neatly laid out- perfect straight lines n everything lol....
monkeywalker
it's difficult to tell whats going on there dude, could you post a schematic diagram style affair instad of a pic.
having said that, there will be someone on here less drunk than i am at the mo who could figure it out from the pic maybe.
Bird
Here's a schematic I drew of the current wiring.
The wiring does look correct - although the coil tap wires are not in place
Connect the green and white from bridge pickup to the tag next to where the yellow wire is . Connect a wire from the next tag along to the back of the volume pot and on the final tag connect the green and white from the neck pickup.
Now disconnect the yellow link wire.
Do positions 2 and 4 sound strong or weak and tinny?
If they are weak then reverse the red and black wires from each of the two humbuckers (as the weak tinny - almost honky sound indicates an out of phase connection
Distance from strings is also a critical factor
If the middle pickup is too far away from the strings and the humbuckers are close you may well percieve a big volume difference
Bird
Positions 2,3,4 are very weak sounding. Not really a honky sound, but you can hardly hear it. And the MMs sound a bit too bright. Next to the yellow on which side?
Bird
Quote from: FELINEGUITARSThe wiring does look correct - although the coil tap wires are not in place
Ok I did the first part and the humbuckers still sounded thin and bright, but I had the middle working. I then swapped the red and black wires around on the humbuckers. Now the humbuckers sound great but the middle pup is back to being barely audible.
Bird
SUCCESS  :!: Thank you so very much Jonathan :D  Your instructions were dead on. The Trilogy wasn't working because the wire was rubbing against the body each time I put it back together, once I re-soldered that connection I was good to go. 2 and 4 are a bit thin, but the MMS were really bright with the reds going to the volume pot. Now it's not only working but I'll be getting my money back from the shop. Thanks again Jonathan :twisted:  :twisted:
Tim
Well done J to the rescue! :D
Tim
Elliot
Any chance of a review of this combo together?
Bird
I'll definitely post a review. Looking forward to crankin' the amp a bit today  :D
