Author Topic: Now I've done it - pulled trigger  (Read 2755 times)
fdesalvo
    • Frank DeSalvo's Music on Soundcloud
« on: April 02, 2015, 10:36:15 PM »
Crawler + MM
Going into this - pardon the crude mock-up.  If it's too dark in this one, I can swap it out for one of the Abraxas's in my other guitars.  Huge shout out to Telerocker for pumping this pickup.  Very excited about the Crawler.  Looking forward to some fat and chewy solo tones and nice split options.
« Last Edit: April 02, 2015, 10:38:13 PM by fdesalvo »
Re: Now I've done it - pulled trigger
« Reply #1 on: April 02, 2015, 11:40:58 PM »
Crawler + MM
How you are going to wire it? Best thing to do is a 500k for the Crawler and 250k for the single coil, like in the Suhr-wiringdiagrams, but those are layed out for HSS. A 250k will maken the Crawler it too dark, a 500k for the neck is a tad bright, but would be better than vice versa. You just have to set the coil a little lower.
« Last Edit: April 02, 2015, 11:48:04 PM by Telerocker »
fdesalvo
« Reply #2 on: April 02, 2015, 11:53:48 PM »
I'll wire it like I have my other Tele wired that is HS (Abraxas/63 Pat Pend): 500K Volume.  Neck hot lead will have a 500K resistor to ground off the switch.   The MM will see this as 250K thanks to Ohm's law.
« Last Edit: April 03, 2015, 12:23:22 AM by fdesalvo »
« Reply #3 on: April 03, 2015, 12:42:21 AM »
Ok, let us know if you like that combo.
fdesalvo
« Reply #4 on: April 03, 2015, 12:43:32 AM »
You better believe it.
