Neck pickup for my ES-335 Dot
Started by everyemptyvein, June 10, 2015, 01:48:17 AM
everyemptyvein
First off thanks for the recommendations on my Les Paul.
I also have an Epiphone ES-335 Dot Studio with a Gibson Dirty Fingers in the Bridge (not changing that). The guitar is all Maple. Does anyone have any recommendations for a neck pickup? I want a neck pickup that sounds kind of like a Tele but more full and a lot of output so I don't have to boost it for solos.
I was going to say get a Mule, but getting a tele sound from it is a tough call!  You could always make it parallel wired, which would give you a thinner sound, but then have a switch to go back to series for solos.  Using a push/pull pot would save putting an extra switch on the guitar.
Chris Rowberry
One option would be to get a Riff Raff neck. With its low output but alnico 5 magnet it will drive the top end nicely. I use the Riff Raff bridge for a tele-like tone myself.
Here to help!
chris@bareknucklepickups.co.uk
littleredguitars2
you could always check out this product that allows the use of an actual tele neck pickup to mount a gibson style rout.
http://www.guitarfetish.com/Humbucker-Rout-adapter-ring-Fits-Tele-Neck-Pickup-THREE-COLORS_p_4351.html
they do a bridge version too. and that goes for both strat pickups and tele pickups.
Even a low output humbucker will have much more output than a Tele neck pickup.
I had good results with Firebird or mini humbuckers for a bright clear tone with more output than a Tele neck.
RiffRaff-neck or a humbuckersized p90 like the Bluenote-neckpickup.
