Author Topic: Which pickups for Les Paul (C-standard)?  (Read 3475 times)
imijj
« on: June 12, 2015, 09:29:21 PM »
I play mostly indie/old school rock/country, but I also really like extreme doomy/stoner-style distortion. Is there a pickup set that I could get that would work for that kind of heavy music while still allowing me to get a warm/usable clean tone?
I run a stereo setup of an Orange Rockerverb 50 MK II and Hovecraft Dwarvenaut 20 into two Matamp 4x12s with Celestion Hot 100's for the dirty stuff, and the Rockerverb's clean channel + a Reverend Hellhound Combo for cleans.
Currently my Les Paul has burstbuckers in it, and I'm just not a fan. My SG has 490 and 498 pickups, and I like them a lot more.
I appreciate any advice you can give.
littleredguitars2
Re: Which pickups for Les Paul (C-standard)?
« Reply #1 on: June 12, 2015, 11:11:28 PM »
i'm thinking mule personally. or the hotter alternative abraxus
darrenw5094
« Reply #2 on: June 13, 2015, 11:08:53 AM »
Warpig for the stoner stuff and it is fine in lower tuning
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
imijj
« Reply #3 on: June 13, 2015, 11:34:00 PM »
Can the warpigs even do clean? Would it be weird to have a warpig in the bridge and a more classic pickup in the neck?
« Reply #4 on: June 14, 2015, 02:48:19 AM »
Warpigs can do clean but you need to wind the volume down a long way.
You might want to combine a Warpig bridge with a different neck.  Even a Juggernaut neck might give a better range of cleans.
imijj
« Reply #5 on: June 14, 2015, 07:21:48 AM »
I see.
Does anyone have any experience with coil tapping the higher gain BK humbuckers? My LP has push/pull coil taps already, and while I don't use it a lot it is something I wouldn't necessarily want to lose.
« Reply #6 on: June 14, 2015, 07:25:05 AM »
Just order the pickups with four conductor wire.
The BKP site has schematics that show you how to wire their pickups to such switches in a variety of configurations, including coil split and series/parallel.  Either mode would cut the output of a Warpig enough to give good cleans.
https://bareknucklepickups.co.uk/main/schematics.php
Won't work with two-conductor wire though.  4-conductor is the default for BKP humbuckers, but just make sure when placing your order.
« Last Edit: June 14, 2015, 07:27:38 AM by Agent Orange »
« Reply #7 on: June 15, 2015, 01:42:34 PM »
black dog should do fine, unless you really want more output
in that case, the holy diver works pretty well as a warpig alternative in low tunings, but it's far more versatile
