Author Topic: Help identifying grounding problem  (Read 6289 times)
rickard.carlsson
« on: July 17, 2015, 09:42:25 PM »
Hi there bareknucklers!
I just bought a new guitar and decided to replace the pickups and electronics.
When I'm not touching anything grounded there is a horrible noise, and when I do, the noise is gone. Exept for the noise, the pickups seem to work as intended.
I've used a multimeter to test the continuity; pickup covers, pickup cavity shielding, bridge, pots and switch has continuity to the sleeve and hot to the tip. The sleeve and tip has continuity when the volume pots are rolled off all the way.
I haven't shrunk all the heatshrink tubings yet and the "ground joint" isn't cramped on both sides yet, I'm doing that when everything is working.
The BKP production technician told me he doesn't get on well with copper shielding, I tried disconnecting the shield, and there was no difference.
Could someone help me identify where the issue lies?
My "wiring schematic"
The wiring itself
If you need more detailed images, tell me.
Thanks in advance
//Sickan
fdesalvo
    • Frank DeSalvo's Music on Soundcloud
Re: Help identifying grounding problem
« Reply #1 on: July 28, 2015, 06:38:18 PM »
I'll try.
I'll look when I'm off work.
« Last Edit: July 28, 2015, 07:36:15 PM by fdesalvo »
fdesalvo
« Reply #2 on: July 30, 2015, 04:31:25 PM »
OK, I don't see anything glaringly obvious.
But, I think you are using more wire than necessary and I'm not a fan of crimping leads.  That's fine for residential electrical work, but I'd only rely on soldered joints in my guitar.
Where are you standing/sitting when you test the guitar?  Near your computer monitor?  Does the noise change with respect to the direction your guitar is oriented?  What's going on under all that heat shrink?  Can you verify if the caps are properly soldered and that the other lugs of the switch don't have stray wire strands touching them?
