November 19, 2026, 08:16:11 PM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Tech
Wiring mistake?
Wiring mistake?
Started by Pos, August 14, 2015, 10:11:55 PM
Previous topic
Next topic
Print
Go Down
Pages
1
User actions
Pos
Junior Flyweight
BKPs:
Logged
Wiring mistake?
Last Edit
: August 14, 2015, 10:53:42 PM by Pos
Hi to everyone. I just swapped the old neck pup of my single cut with a BKP The Mule. I have 1 vol, 1 tone, 1 three-way miniswitch series/coil tap/parallel for the neck pup, and 1 two-way miniswitch series/coil tap. In the neck position, everything works fine: series, single and parallel modes all sounds fine. But, when I swap to middle position, the sound is too crispy and edgy than before.
For the neck mini-switch, I followed this diagram:
https://bareknucklepickups.co.uk/main/downloads/schematics/profiles/humbuckers/1hum__4_con_pushpull_pot-series_or_parallel.pdf
The red cable is soldered in the pin with the red cable from the selector, and black cable goes to ground on the tone pot. This is exactly as it was before pup swapping.
You can hear a couple of samples, both middle position neck parallel/bridge coil tap.
https://soundcloud.com/carlos-rivera-512/sets/asking-for-help
Did I do something wrong? Any Idea?
Thanx to anyone.
FIXED
Pos
Junior Flyweight
BKPs:
Logged
Re: Wiring mistake?
#1
August 17, 2015, 01:52:58 PM
Any idea? Please help.
If I won't receive any suggestion by thos evening, I think I willl try to swap the positives.
Pos
Junior Flyweight
BKPs:
Logged
Re: Wiring mistake?
#2
August 19, 2015, 11:49:30 PM
Just tried to flip the magnet inside. Tomorrow I'll check the wires, now I'm tired.
Pos
Junior Flyweight
BKPs:
Logged
Re: Wiring mistake?
#3
August 20, 2015, 11:03:13 AM
Soldered all the wires correctly. Doesn't sound soo different, it's just a little more smooth and less edgy. I undervalued the importance of pup adjustement. Setting up the pup and screws height brought very good results.
Print
Go Up
Pages
1
User actions
Forum Ringside
Tech
Wiring mistake?
User actions
Print
