Best Height for Rebel Yells?
Started by farleyuk, August 15, 2015, 01:19:03 PM
farleyuk
Hi all,
Got a set of RYs in my Les Paul, and just wondering what everyone has theirs set at, height wise? I know they're very sensitive to height changes, and I'm curious what the general consensus is about the pup height (my bridge is set to about 2mm, BTW).
darrenw5094
Seems to be the closer, the better with the RY.
Just curious as why you are asking, are you happy with the pickup set?
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
darthphineas
I usually start most any pickup with 1/32" to 3/64" on the high E and 3/32" on the low E and go from there. Going about 1/4 turn of the adjustment screws at a time. Depending on things, I may also tweak the screw poles to balance string volume or match the string radius. All depends. Just play around and see how things develop.
[url="//www.darthphineas.com"]www.darthphineas.com[/url]
www.facebook.com/darthphineas
www.twitter.com/darth_phineas
www.instagram.com/darthphineas
Chris Rowberry
We get asked quite a lot. We always recommend lowering it right down and simply play and rise until you feel you have hit the optimum height for what you perceive the be the best tonally.
Here to help!
chris@bareknucklepickups.co.uk
richard
I played around with mine for weeks to get them where I wanted. I started with them really high and gradually lowered them. Then I did it the other way round. I didn't measure anything at the time but I've just done it and I have my bridge at about 5mm and the neck around 4mm. They sound better to me backed off a little.
PRS S2 Singlecut RY's
JV Strat  IT Bridge
Gibson SG JB bridge
Fender Bassbreaker 15
Yamaha THR 100 Dual
Quilter Aviator Cub
farleyuk
Cheers guys - I'm basically after the hottest response with some sizzle and bite, but obviously without any ill effects!
Just played around a bit more - seems about 3mm for the bridge and 4 for the neck works well for me.
