Jugg. Short or long legs?
Started by oceansandatlantic, August 22, 2015, 09:23:05 PM
oceansandatlantic
Does anyone know if the jugs are short or long legged? It didn't give me a option to choose and I have it going in a fender Jim root(using a pickup ring) it should fit either way right?
#1
There should be an option there in a drop down box.
Long legs are basically for Gibsons and other guitars with a noticeable neck angle and/or pickguard mounted pickups.  Sometimes the cavity is too shallow for long legs.
EDIT: I just checked and that's really weird.  There is no option for leg length on Juggs.  I checked Cold Sweat and the option is still there for that model.  Maybe use the messaging function on the web store to ask directly.  The option is available on all of the other ones I checked - Painkiller, Aftermath, Warpig - except for the Black Hawk
oceansandatlantic
haha i know right? i did the same thing except with the holydiver it gave me the option. maybe the juggs only come in short? i guess ill have to message them and ask thank you!
That seems odd to me, given that the Aftermath and Warpig seem to have the same baseplate but have the option of long or short legs.  Is the overall height of the Juggernaut different from those models?  Does that mean that long legs are impractical?
darrenw5094
Something to do with the magnets i think
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
Chris Rowberry
Hey Guys,
It's because the magnets are 6.35mm so are a lot taller than all other Bare Knuckle models. We even had to have a tool made for the covers because of the magnets being bigger.
You can get an idea of the difference from these.
Juggernaut -
https://bareknucklepickups.co.uk/main/downloads/dimensions/humbuckers/50and53mm_juggernaut.pdf
Standard Humbucker -
https://bareknucklepickups.co.uk/main/downloads/dimensions/humbuckers/6_string_standard_spacing.pdf
Here to help!
chris@bareknucklepickups.co.uk
Quote from: Chris Rowberry on August 26, 2015, 08:23:03 AM
6.35mm is TALL indeed
regular models have 3mm (alnico) or 4mm (ceramic), right?
oceansandatlantic
Oh okay got ya. Thanks
It shouldn't give me any problems fitting in a Jim root Tele(pickup ring) will it?
Chris Rowberry
[/quote]
Yep, the magnets we use are normally 3.2mm alnico and 4mm Ceramic magnets.
Quote from: oceansandatlantic on August 27, 2015, 02:29:57 AM
You shouldn't have any problems at all fitting a Juggernaut to your Jim Root Tele    :smiley:
Here to help!
Yellowjacket
I'm late to the party here but I can attest to the fact that the Juggerbridge is one thick pickup.  It's also one amazing pickup and I really like it in my superstrat!
