Author Topic: Problem with BOSS SD1 pedal - Battery Vs Mains Power  (Read 7402 times)
Brow
« on: March 29, 2006, 12:15:47 PM »
Hey guys.
I've been digging out alot of my old gear lately, and came across an old Made In Japan BOSS SD1 Super Overdrive that I bought years ago, but haven't used in a while.
I powered it up with a 9V mains adaptor that I had handy, and noticed that the on/off LED was quite dim when the pedal was switched on. I then tried the pedal with a 9V battery and the LED was alot brighter when the pedal was switched on.
I also tried the SD1 with a brand new Diago Powerstation Pedalboard Power Supply and the LED was still dim.
Does anyone know what the problem may be, and how I could get it repaired?
Craig
jimi hendrix
« Reply #1 on: March 29, 2006, 12:35:09 PM »
http://www.freeinfosociety.com/electronics/schemview.php?id=169
if its any good theres a schematic here :D
Brow
« Reply #2 on: March 29, 2006, 01:59:46 PM »
Quote from: jimi hendrix
Thanx for the schematic Jimi :)
Apparently, these older Japanese BOSS pedals were made to run on a 9v battery or a 12v mains power supply. Something to do with a diode/resistor that's fitted before the power jack as a safety against using a power supply with the wrong polarity.
If this is the case, am I still safe to use a 9v adaptor with it?
willo
« Reply #3 on: March 29, 2006, 02:06:10 PM »
I'm not certain on this, but weren't some of the older boss pedals AC rather than the newer DC?
Brow
« Reply #4 on: March 29, 2006, 02:34:28 PM »
Quote from: willo
I'm not sure to be honest.
The SD1 works fine on a 9v battery and, on the suggestion of someone on another forum, I tried it with a 12v adaptor and the pedal worked fine.
Jp.
« Reply #5 on: March 30, 2006, 11:15:08 AM »
Try the www.bossarea.com forum
The guy that runs it and a couple of the regulars are really up on the actual electronics nitty grtty of the pedals
Mule, Irish Tour and Slowhands
Brow
« Reply #6 on: March 30, 2006, 12:22:29 PM »
Quote from: Jp.
That's where i got the info from about there being a diode/resistor wired before the power jack to safeguard against incorrect polarity :)
I tried the SD1 with a 12v PSU and it worked fine :)
Jp.
« Reply #7 on: March 30, 2006, 12:35:54 PM »
Glad I could be of Latent help
