Author Topic: Abraxas in Rg?  (Read 3952 times)
m t soule
  • VHII n,, HD b, NB b, CR n, ITm, Ab, Cs, Mm
    • Golem Painting Studio
Abraxas in Rg?
« on: November 24, 2015, 11:36:07 PM »
What do you guys reckon?
Abraxas bridge, crawler neck in basswood rg?
RG550-Cr(n) S1(m) Ab(b)
RG550-VHII(n) IT(m) HD(b)
RG550-Cs(n) mm(b)
Jem-sfty3rds
Jem-Evo set
Jem-breeds
Frm250-air classic
had-Ry(b)  Nb(b)
Re: Abraxas in Rg?
« Reply #1 on: November 25, 2015, 09:25:57 AM »
Abraxas bridge should be fine.
Is this a 24 fret guitar? In that case I would consider the VHII neck.
  • Random Solution
Re: Abraxas in Rg?
« Reply #2 on: November 25, 2015, 01:02:31 PM »
The Abraxas and Crawler neck models are pretty much the same anyway, though the VHII is certainly different. Another option you might consider is the Holydiver neck, which is a very light wind but the AV magnet and more modern wire help to give it a bit more articulation.
m t soule
Re: Abraxas in Rg?
« Reply #3 on: November 25, 2015, 01:25:46 PM »
I already own the Cr neck lying round and was looking for a good match for it.
It seems i wasnt far of with the abraxas then!
The vhii would be a very different feel to a crawler which is fat n round.
Im going to using the guitar (yes 24 fret) to experiment with. Things like altered tunings, dropped tunings, ambinent sounds. Nothing too aggressive but keeps that option open a little.
RG550-Cs(n) mm(b)
Jem-sfty3rds
Jem-Evo set
Jem-breeds
Frm250-air classic
had-Ry(b)  Nb(b)
Re: Abraxas in Rg?
« Reply #4 on: November 26, 2015, 09:27:19 AM »
Spec-wise they are similar but they do sound different. Abraxas is noticeably brighter. I had them back to back in the same guitar.
m t soule
Re: Abraxas in Rg?
« Reply #5 on: November 26, 2015, 03:47:21 PM »
Are you rdfering to Cr bridge to Ab bridge or Cr neck to Ab bridge.
Its the latter i am looking for info for
RG550-Cs(n) mm(b)
Jem-sfty3rds
Jem-Evo set
Jem-breeds
Frm250-air classic
had-Ry(b)  Nb(b)
Re: Abraxas in Rg?
« Reply #6 on: November 27, 2015, 09:41:14 AM »
I was talking about the neck pickups - both AWG 42 plain enamel and A4 magnets, Crawler neck being wound a bit hotter going by DC resistance. I would not have expected the Abraxas neck to be a lot brighter than the Crawler neck but it was in that particular guitar I had both in.
Sothoth
Re: Abraxas in Rg?
« Reply #7 on: November 28, 2015, 07:16:10 PM »
+1
At least in my rig, they sound almost identical except the Crawler is higher output.  Different woods or amps may skew the sound as well.
m t soule
Re: Abraxas in Rg?
« Reply #8 on: November 30, 2015, 03:27:02 PM »
I took the plunge on the abraxas bridge.
Wow......never expected any of that.
Its brilliant........
RG550-Cs(n) mm(b)
Jem-sfty3rds
Jem-Evo set
Jem-breeds
Frm250-air classic
had-Ry(b)  Nb(b)
