Author Topic: What is BKP's view on the tone wood debate?  (Read 17998 times)
Chargrilled
« on: November 25, 2015, 11:47:24 AM »
There seems to be two parties on opposite ends of the spectrum, so the question is does the type of wood actually effect the tone or is it a myth...
Re: What is BKP's view on the tone wood debate?
« Reply #1 on: November 25, 2015, 01:01:15 PM »
My attitude is that the wood in the guitar is part of what is vibrating when playing and so it will have an impact on the overall tone of the instrument at some level.  I don't subscribe to simple-minded generalizations about a type of wood with regard to tone because I own SGs and I can tell you that SGs sound more alike regardless of whether they have maple or mahogany necks than they sound like other mahogany guitars like Explorers.  I have noticed a pronounced brightness to maple fingerboards compared to rosewood ones when comparing otherwise similar basses, however.
What I will say is that the more open and less compressed a pickup is the more the acoustic differences between instruments seem to matter.  I think this is a major reason why BKPs tend to react very differently to different guitars while some other pickups do not.
Chargrilled
« Reply #2 on: November 25, 2015, 02:29:58 PM »
Ok cool thanks for the response
BigK
« Reply #3 on: November 26, 2015, 09:21:39 AM »
I think Tone Woods are just part of the mix personally.
I thing they do have an effect but its also about the amount of wood there, the shape of the body (effects how the wood can resonate), the construction of the guitar, Set Neck, Neck-Thru, Bolt on etc.
And then there is the finish... thick finishes can stifle the resonance of a guitar.
For example I have three PRS Tremonti's and all three sound different acoustically and therefore plugged in even with the same pickups, construction and hardware. Do they all sound like Tremonti's yes just that one has a boomier, thicker bottom end, one a more rounded upper midrange and one that's very tight and aggressive.. all slight but noticeable differences around the same general theme.
« Reply #4 on: November 26, 2015, 02:02:07 PM »
Yeah out of my three SGs the two with the satin finishes are more resonant than the one with the full gloss clearcoat (the SG Standard), even though the the Standard is a lot more resonant than my Epiphone Explorer.  The latter has a polyurethane finish but I think the difference in body style and neck joint (and thicker maple neck) probably have more influence on that than the type of finish.  But you can hear the difference when comparing my three all mahogany SGs.  My SG Special is very similar to my SG Standard (same woods, same routing) except for the finish.  The three Gibsons are all very loud acoustically. The Epi is much less so, but the Explorer design has considerably more sustain.  I did notice that the sustain increased with the fitment of a TonePros bridge and tailpiece set, but my two tune-o-matic SGs have those as well.
« Reply #5 on: November 26, 2015, 08:04:28 PM »
Combination of tonewoods can make a dramatic difference. An ebony fretboard will usually give more snap and percussiveness than rosewood. But the construction - glued in neck, neck-thru or bolt-on - has an effect too. So does the bridge. In the end the pickups can do a lot too. There's not really a general rule to predict the result, even when guitars are made to the same specs.
« Reply #6 on: November 26, 2015, 10:48:24 PM »
I think that the wood is part of a number of elements that affect tone but I don't really buy into the attributed tonal qualities of various woods. I would expect the neck construction  to have a bit of an influence too . I can't claim any scientific evidence to support my opinion however and I certainly wouldn't bother to argue the toss over it.
« Reply #7 on: November 27, 2015, 09:58:17 AM »
It seems to me that often two aspects of wood are not distinguished enough in such discussions - the air resonance of wood on one hand and the effect of wood on the string vibrations on the other.
The wood used in electric guitars does not make the electric guitars have air resonance (like an acoustic guitar has). This is why you may hear more of the string vibration when you play the guitar unplugged while holding it against a table and then taking it away. You will hear the difference unplugged but you will not hear a difference when the guitar is plugged into an amp. Why is that - well, the pickups in the guitar do not pick up air resonance. They pick up the strings vibrating.
However, that does by no way mean that wood does not have an influence on the final sound - it does because the wood (together with the entire construction of the guitar) affects the string vibrations which then get picked up by the pickup and are converted into the tiny electric signal that is then amplified. Frequencies not contained in the string vibration cannot be brought back by pickups, amps or pedals.
Another aspect comes into play when you play an electric guitar at a certain volume level. In that case the guitar picks up the acoustic sound coming from the speakers - which in turn again affects the string vibration. I feel that guitars made of certain woods (noteably alder and mahogany) seem to feedback easier than others (e.g. ash).
« Reply #8 on: November 27, 2015, 10:00:47 AM »
I will say that I never had an alder guitar I didn't like the sound of. I also only had one mahogany guitar that sounded like arse.
But I think the individual piece of wood itself makes more of a difference than the species itself. I'd rather have a guitar made of a great piece of poplar than a bad piece of mahogany.
Anyway, I would say - yes - wood clearly affects the tone. Quite alot as well, and its the only thing other than the construction you can't change once you've brought the guitar. So for me, its probably the most important aspect of tone. But as Mr 38th says : "I don't really buy into the attributed tonal qualities of various woods"..
« Reply #9 on: November 27, 2015, 10:56:43 AM »
+1 for gwEm's contribution. Quality of the wood counts: by example cheap basswood and topnotch basswood that Suhr uses.
Elliot
« Reply #10 on: December 08, 2015, 10:49:21 AM »
The latest in the tone wood debate.  I suppose cardboard was wood once.  :evil:
https://www.youtube.com/watch?v=7Oo2H-W7d6A
« Last Edit: December 08, 2015, 03:11:04 PM by Elliot »
« Reply #11 on: December 08, 2015, 10:58:00 AM »
The latest in the tone wood debate.  I suppose cardboard was wood one.
Yeah, I saw that vid. Hope the guitar doesn't get wet.
Elliot
« Reply #12 on: December 08, 2015, 08:00:40 PM »
It must have some lacquer on it - maybe even an epoxy resin - otherwise I can't see how one could play the fret board.
« Reply #13 on: December 09, 2015, 12:15:09 AM »
100% correct. Impressed by the strat I watched some more of their videos and they coat the cardboard in epoxy resin
Alfi27
« Reply #14 on: December 09, 2015, 02:02:01 AM »
Speaking from my own experience: Wood has a huge impact on tone. I have two guitars that are quite similar, especially the construction and shape. Suhr Modern (alder body, all maple neck, bolt-on, two point tremolo) and Mayones Setius (mahogany/maple body and neck, bolt-on, hardtail). The Suhr's body is actually a bit thicker as well. However, they sound nothing like each other. The Setius sounds close to a Les Paul, and the Suhr sounds bright and lacks the balls of a mahogany guitar. I also owned a Suhr S4 with basswood/maple body for a few days, with Suhr ML pickups in the neck and middle. It sounded extremely bright and extremely dull and lifeless at the same time... So I have figured that I will probably not get another guitar with anything else than mahogany! Maybe I will get an alder strat just to have one, but mahogany will always be my favorite by far!
