Humming problem with solid state amp
Started by 5F6-A, March 05, 2016, 09:10:38 PM
5F6-A
This amps hums loudly when a guitar cable is plugged into it but left not connected to the guitar; when connected to the guitar the hum diminishes but still louder than I think is permissible. It's further reduced when I touch the strings or any metal part of the guitar. When I turn the guitar volume knob to zero, the amp is quiet as a mouse.
One extra piece of info that might be important. When I feel the brass surrounds of the metal socket where the amp is plugged in, I can feel a tingling sensation. As soon as I unplugged the amp from the wall socket the tingling goes. What is this? Is the amp at fault? Is that socket at fault? Maybe more importantly... is it dangerous (i.e. can i get a shock?)?
This is the type of socket that I use:
What's happening? ? I'm suspecting a grounding issue but unsure of its origin or how to solve it...
"I now consider atheism to be brutal because it offers neither consolation nor liberty of any kind" Benjamin Constant in 1804
"Practice until you can hear the metronome grooving" Carol Kaye
GuitarIv
#1
I'll do my best to help you out: when the guitar cable tip touches the floor while being plugged into the amp you get hum, I can't tell you exactly why (regarding the physics behind the whole thing) but that's just a natural thing that happens. Every guitar player has experienced this before.
The fact that the hum is diminished the moment you touch your strings has something to do with interference; your body actually produces a whole lot of EMI, again I can't actually explain why but as soon as you ground yourself via the bridge connection to your guitars output (by touching the grounded parts of your guitar) you have a path going from your body to earth: the noise goes away.
Of course the amp is gonna be dead silent as soon as you turn your volume knob to zero: you cut out the signal and every interference that gets in the way of the signal.
The tingling sensation is very probably current finding it's way through your body. As long as it's only tickling your fingers it's not dangerous, however it's a strong indicator that something is wrong with either your guitar wiring, your amp or the socket wiring in your house. If I was you I'd get my guitar checked by a tech, if the problems persist I'd either get a new amp or try out a different socket.
Hope someone else who's knowledgeable chimes in and contributes  :smiley:
Cheers
